Mud tire choice
Old Dec 22, 2009 | 06:31 PM
wolfmanii's Avatar
Default Mud tire choice
Just installed Bushwacker Flat Fender on my JK
now with stock suspension, my JK is good to clear 33 inch tire.
Now I am facing a wide range of Mud tire choices.
So far I narrowed down to the following tires
Good Year MT/R with Kevlar 305 70R16
BFGoodrich KM2 305 70R16
I am planning to use 16x9 steel wheel with 5 inch backspacing.
How do you think about the tire, also, is my wheel choice good or bad.
By the way,Did anyone tried 34 inch tire for the same situation as mine?
Old Dec 22, 2009 | 08:30 PM
Stuka's Avatar
The MT/R's have a stronger sidewall and are quieter on the street.
For the wheels, I would go with 4.25 or 4.5" BS. Where did you find 16x9 steel wheels?
Old Dec 22, 2009 | 09:05 PM
wolfmanii's Avatar
Thanks, my preference is also good year MT/R
As for the wheel, I prefer to have it 9 inch wide. but it seems no 16 inch wheel
has 9 inch width. SO I guess I have to use 8 inch width.
I am not sure if this will cause problem because the tire is 12 inch wide
Old Dec 22, 2009 | 09:25 PM
MTPOCKETS's Avatar
X2 on the BS. On the other hand I would go with the KM2's.
Old Dec 23, 2009 | 05:09 AM
Wings fan's Avatar
x3 on the BS. And I like my KM2's I'm not sure that MTR's are quiter but I would agree they have a stronger sidewall. The Side wall can be a benifit or a problem. My KM2's aired down have a great pattern at 12psi and are crazy at 7-8psi.
Also I'm running 35x12.5 on 8 inch rims and think its perfect. I was with a guy running 12.50 on 10" rim and rolled his tire off the rim on something I walked through with no problem. So if I were you I'd go 8 over 9, Although this advice all centers around trail riding.
Old Dec 23, 2009 | 05:14 AM
Stuka's Avatar
The center of the tire will wear a bit faster with it on a narrower wheel, but it will also hold a bead better when aired down because the tire is being pinched a bit more.
Old Dec 23, 2009 | 05:15 AM
dhughes's Avatar
I have 33x13.5x17 IRoks and love them. got 26000 miles on them and holding up great. Im about to up to 36 IRoks at the fist of the year. They pull like crazy in the mud and rocks.
Old Dec 23, 2009 | 05:18 AM
JasonTCFD's Avatar
I love my KM2's, They are a lil loud on the street, but they are awesome and a mud tire what do you expect.
Old Dec 23, 2009 | 05:28 AM
BBirish's Avatar
i LOVE my km2's
Old Dec 23, 2009 | 05:53 AM
robin's Avatar
I would really try to find a wheel with at leas 4.75 bs, as far as the tires I think they are both good. I run km2's in my truck, they seem good.
