TIRES ARE COMING! Things to prep? Help plz
Old Feb 8, 2010 | 09:17 AM
runit3's Avatar
Default TIRES ARE COMING! Things to prep? Help plz
All right so I just spent more money than I am willing to realize at the moment on my new set of wheels
Rim
KMC XD Addict 798's in 18x9 (5x5) 4.5" backspacing
Tire
Toyo M/T 38x13.5R18's -True inflated tire diameter from manufac. spec. 37.7"-
I have a full set of spidertrax 1.5" spacers but I DO NOT really want to run them, the heaviest tire/wheel set possible is going to be putting enough strain on my 44's as it is.
This being said, what preparations do I need to make for these tires to fit. I have 4" Tuff Country lift no body spacers, pucks, etc.
I know I have to trim the stock rubi rails and the pinch seams, what else?
Suggested axle upgrades? gussets, sleeves? what will/won't help axle strength due only to tire size/weight.
Thanks
Old Feb 8, 2010 | 11:01 AM
sclan's Avatar
First you'll need to make sure you recharge your digital camera batteries cause you'll want to take a lot of before and after pics of those bad boys! And we'll want to see them
Old Feb 8, 2010 | 11:04 AM
runit3's Avatar
I've got the Big SLR ready to go w/ plenty of space
The more I think about this the more I feel I should be putting an order in to M.O.R.E. for the body lift ASAP. Also trying to install the BL with 38's is going to be a task...I don't have mountains of 2x4's lying around to reach the gap from jack to frame
Old Feb 8, 2010 | 11:09 AM
LSUjeepguy's Avatar
I'd definately suggest gussets and sleeves at the very least...
What gears are you going to run?
Old Feb 8, 2010 | 11:12 AM
runit3's Avatar
5.13's. IMO I'd rather plow a u-joint than shred my 5.38's-I'm fairly liberal with the gas. Gears+Install= more $ than swapping a drive shaft or joint
Old Feb 8, 2010 | 11:14 AM
mkjeep's Avatar
You may have to run the spacers in the front with them being 13.50's. Try it without first. But you may rub when flexed.
Old Feb 8, 2010 | 11:18 AM
runit3's Avatar
I'm pretty much counting on the rub w/inner fender plastic The sway bar links will need to stay connected until I can find a nice spot to get a full flex test run in. I'm more worried about the LCA's in the front getting knicked on full turn in/out.
Old Feb 8, 2010 | 12:33 PM
MOJEEP's Avatar
Bump. Someone help him out. I would think you would need a body lift to clear the big meaty's. My 35's have problems with my 4" skyjacker lift.
Old Feb 8, 2010 | 12:42 PM
jeeperjkjeeper's Avatar
Default spacers?
how much do you want for your spacers if you end up not needing them?
Old Feb 8, 2010 | 08:57 PM
runit3's Avatar
what problems do you have with 35's?
I'm probably going to hang on to the spacers even if I don't use them as a DD, I like them on the trails
