Front lower control arm bracket
Old Mar 22, 2010 | 07:00 AM
rhino4bs@yahoo.com's Avatar
Default Front lower control arm bracket
On axle is cracked is there a better aftermarket bracket that can be welded on there to replace stock ones
Old Mar 22, 2010 | 07:44 AM
highoctane's Avatar
There's a few places that sell aftermarket brackets. Where is it cracked? If it's only the weld tha cracked, you could reweld it on both sides of the bracket to reinforce, both on the inside and outside. Also it's a good idea to get a set of the Offroad Evolution lower control arm mount skid plates. Reinforces the mount by boxing it, and it's 3/16 steel which will take a beating from the rocks and not sustain damge to the mount.
Old Mar 22, 2010 | 08:31 AM
0311sgt's Avatar
Check out rockrawler lower control arm brackets/skid plate. I have been running them for 2 years now and they can take a HELL of ALOT of abuse.
http://www.rockkrawler.com/
i recommend the brackets and the HIGH clearance lower control arm.....WELL worht the price and their customer service is PHENOMANAL!!!
2007 JK Unlimited 6 Speed 4.10 Gears
3 Inch BDS Lift
35x12.5x16 Yokohama Geolander AT/S
16x8 Cragar Soft 8 Black Steel Wheels
Custom front Winch Bumper from RoundStar OffRoad
Mopar Offroad Rear Bumper
Oilpan/Tranny skid Plate by Skid Row
JKS Quicker Disconnects
Skyjacker Brake line extenders
Skyjacker Adj Rear track bar
High Clearance Adj Front Lower Control Arms by RocKrawler
RocKrawler Front Lower Control Arm Mounting Bracket/Skid Plates
Warrior Products Rear Safari Doors
Plenty of ROCKRASH
Old Mar 22, 2010 | 08:40 AM
metaulic's Avatar
I think currie as well as poly has these brackets. But personally id just get a welder buddy or some guy who'd do it for a case of beer.
