removing shift knob
Old Dec 15, 2006 | 10:53 AM
jameswharton's Avatar
Default removing shift knob
Before I tear something up, does anyone know the proper way to remove thre factory shift knob. I am looking at putting something a little more ergonomic on.
Thanks,
Jim
Old Dec 15, 2006 | 11:13 AM
wayoflife's Avatar
JK-Forum Founder
I haven't tried it myself yet as I do not have a JK yet but if it's anything like the TJ's, you will have to pry off the shift pattern plate with a small screw driver in order to expose the nut securing the knob in place.
ID:	243653   Click image for larger version
ID:	243654   Click image for larger version
ID:	243655   Click image for larger version
ID:	243657   Click image for larger version
ID:	243659   Click image for larger version
Old Dec 15, 2006 | 11:57 AM
SpudRacer's Avatar
I remember reading that same thing, about 1 month ago, the new JK didn't have threads, was just pressed on. Sounds like we need someone who already has a JK to go do some yanking on their shaft (here we go again...). I can always try, on my next trip to the dealership, and yank on their shaft, not that I'm into yanking on shafts, mind you....
Tom
Bryson City, NC
ID:	244471   Click image for larger version
ID:	244472   Click image for larger version
ID:	244473   Click image for larger version
ID:	244474   Click image for larger version
ID:	244476   Click image for larger version
ID:	244477   Click image for larger version
ID:	244478   Click image for larger version
Old Dec 18, 2006 | 03:20 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Tom
Bryson City, NC
"...not that there is anything wrong with that..."
ID:	263304   Click image for larger version
Name:	flexing jeep 2.jpg
ID:	263305   Click image for larger version
ID:	263306   Click image for larger version
Name:	JK flexing.jpg
ID:	263307   Click image for larger version
ID:	263309   Click image for larger version
Old Dec 18, 2006 | 04:31 AM
jdrogers's Avatar
I checked the FSM and there is nothing about removing the transmission gear shifter knob.
For the transfer case shifter you just pull up and it comes off.
Everyplace they are doing something with the transmission gear shifter it has you removing the boot from the console (by just prying up with a trim price tool) and then removing the shifter from the transmission itself. There is one bolt under the boot to remove the entire shifter.
You could go by the dealer and ask them to look at the ordering information diagram. It should show the exploded parts diagram for the shifter.
Old Dec 18, 2006 | 06:59 AM
Jake_Blues's Avatar
Well, over the weekend I tried taking off my JK's shift knob, and couldn't figure out how, without destroying anything. I couldn't pop off the shift pattern plate, I pried hard enough to chip the plastic without any luck. I didn't get out the strap wrench to try turning the whole thing, but I tried to turn it with my hands and couldn't budge it. Hopefully the thing is threaded under there, but a press-on wouldn't surprise me too much, given the cost savings of not having to thread the thing.
-E
ID:	264381   Click image for larger version
ID:	264382   Click image for larger version
ID:	264383   Click image for larger version
ID:	264384   Click image for larger version
ID:	264386   Click image for larger version
ID:	264387   Click image for larger version
Old Dec 18, 2006 | 07:40 AM
wayoflife's Avatar
JK-Forum Founder
This is a shot of my TJ's shift knob after removing the shift pattern...
As you can see, the nut securing it in place is underneath it and yes, it is a real pain in the but to remove the shift pattern.
ID:	264440   Click image for larger version
Old Dec 18, 2006 | 12:29 PM
Jake_Blues's Avatar
Question is, are the JKs done the same way as the TJs were? Short of dissecting a shift knob on an '07, not sure how we can find out, since the service manual doesn't mention it! I really want a nice black anodized billet knob...
-E
Old Dec 18, 2006 | 01:19 PM
tolh13's Avatar
just pull straight up.its a push on.i swap mine out fir a rock shifter(no rocks in fl.)
ID:	266125   Click image for larger version
ID:	266126   Click image for larger version
ID:	266127   Click image for larger version
ID:	266128   Click image for larger version
ID:	266130   Click image for larger version
ID:	267346   Click image for larger version
ID:	267347   Click image for larger version
ID:	274493   Click image for larger version
Name:	IMG_0435_fr bumper.jpg
Old Dec 18, 2006 | 02:47 PM
Jake_Blues's Avatar
Bah. Now I'll have to take mine and get one of the guys in the shop at work to thread it.
-E
