removing shift knob
Old Apr 26, 2007 | 12:46 PM
Ddealer's Avatar
Default how???
How do you remove the shifter that takes you from 2 wheel drive to 4x4???
i took off the gear shifter knob... but the other one is realllllllly hard.
Old Apr 26, 2007 | 04:58 PM
G16's Avatar
G16
The knob is pressed on, no threads. There is no bolt underneath the shift plate.
Old Apr 27, 2007 | 12:50 AM
SrfrGrl's Avatar
Ok has anyone figured out for sure how to remove the new shift knobs?...i've tried everything aside from literally ripping it out which is what i'm about to do since it is frustrating me so much.
Also, once removed if there are no threads how do you get/make threads to add a different knob?
Old Apr 27, 2007 | 02:58 AM
dougr5150's Avatar
Just a quick tip for removing the shifter knob. Get a large adjustable wrench and tighten it up so it is just a tiny bit loose on the shaft below the shifter knob, then hold it tight up against the bottom of the knob and take a BFH and hit the wrench in the upward direction. A couple of good hits and the knob will pop right off.
Old Apr 27, 2007 | 05:16 AM
tjworld's Avatar
I am not too sure about using a large wrench or a BFH around my knob.
Old Apr 27, 2007 | 06:05 AM
dougr5150's Avatar
Some how I just knew someone would make a comment like that
Old Apr 27, 2007 | 06:39 AM
jwseely's Avatar
Default Shift Knob
Don't want to beat a dead horse (or tear up my stock knob unneccessarily) but has it been confirmed that the stock knob is NOT threaded and just "pushed" on? --Therefore requiring only a "great" force to pull the knob off??
Thanks, I'm new to all this..
Jonathan
Old Apr 27, 2007 | 07:16 AM
HappyCurmudgeon's Avatar
Eternal ***erator
according to the factory service manual for the T-case knob:
"1. On 4x4 vehicles grasp the transfer case shifter knob and pull straight up and remove the knob. "
Having trouble finding how to pop your knob for the auto or manual shaft.
Old Apr 27, 2007 | 04:01 PM
SrfrGrl's Avatar
so how do you get your shaft threaded (i know there will be a dirty reply to this lol) or can you buy knobs that are push ons? geez i cant wait til they get more accessories for the JK's
Old Apr 27, 2007 | 11:49 PM
Dr.McNinja's Avatar
You're going to put this on aren't you?
Note, I don't think this is technically a competing vendor so I think I am safe with the rules
