Putting in the windows
Old Aug 7, 2010 | 10:52 AM
nickythegreek's Avatar
Default Putting in the windows
I am having a hell of a time trying to get the windows in properly !!!! I can't seem to get the part that goes inside of the door in properly for a proper seal , anyone have suggestions ?
Old Aug 7, 2010 | 10:57 AM
JayhawkJeep's Avatar
Veteran: Navy
Try adjusting the flaps in the back.
Old Aug 7, 2010 | 10:59 AM
will do, thanks
Old Aug 7, 2010 | 11:01 AM
actually , I forgot to ask , is the window supposed to sort of clip into the door rail ?
Old Aug 7, 2010 | 11:07 AM
Veteran: Navy
No, the plastic just sits there and when aligned right it forms a seal with the door when it shuts.
Old Aug 7, 2010 | 11:08 AM
ok cool , thanks
Old Aug 7, 2010 | 11:10 AM
CrystalRubi's Avatar
I always do that part first, where the door closes, after starting the zipper a couple of inches. I've found it is much easier to get it around the door frame before everything else is tight. After the zipper is started and the door frame is in place, then I tuck the bottom of the windows in, finish zipping them up and velcro.
Old Aug 7, 2010 | 11:31 AM
Thanks !!!!
Old Aug 7, 2010 | 12:34 PM
Mark Doiron's Avatar
Many folks get this part incorrect, causing the window to pull out at high speeds. Here are some pic's that Happy Curmudgeon has provided ...
http://my.project-jk.com/search.php?searchid=28177&cpage=3
Bottom line: It rolls around ninety degrees further than it might at first seem.
Old Aug 7, 2010 | 07:11 PM
That link totally helps , thank you so much !
