Modified JKS Front Track Bar
The new re-designed JKS front track bar is approximately an inch and a quarter shorter than the original track bar. Just wondering if anyone else has noticed the shorter length after replacing their old design with the new design?
Asking because I have much more thread showing now with the newer design - just seems like it wouldn't be as strong.
Primary concern is the loss of inserted threads due to a shorter bar. Planning on a big ride soon, and don't want to tear things up, plus I need to be able to drive my Jeep the four hours it will take to return home.
Also, now I have it installed, the new design looks like it could hit my ARB diff cover. Need to perform some flex "tests" to verify, but I'm concerned at the moment. After I check, will follow up with my findings on the possible interference issue (for the record, I have not been using any sort of aftermarket front track bar bracket).
I didn't receive any instructions with the JKS trackbar "upgrade", but was told no one has had any interference issues yet with their ARB diff cover. Good thing I kept the original bar - may have to make an emergency un-modification.
We have had zero issues with the new JKS Trackbar. Zero
Also we have installed a ton of them and we have not seen a diff cover that it rubs on and We have not had any calls with any issues.
I am fairly confident that JKS is among the top two of most popular trackbars so if there was a Issue we would know about it.
David
David
Also, anyone else running the new design have a pic of the axle end insert threaded into the bar . . . would be nice to know if they all look "unthreaded" like mine.
Anyways,I have 6 threads exposed. Looks like thats about what you had originally.
David
David
