Soft top question....
Old Mar 2, 2011 | 04:45 PM
jkinportland's Avatar
Default Soft top question....
I hope I am posting this in the right place. Will a 2008 factory 4 door soft top fit a 2010 4 door? Is it the exact same thing? Thanks!
Old Mar 2, 2011 | 05:51 PM
curtise's Avatar
I can't speak for the 4dr assuredly, as I have a 2 dr, but in short - mostly yes.
They're the same, except that the door surrounds on an 08 are less user-friendly than the 2010. More importantly, you can't attach an '08 soft top to 2010 door surrounds. The 2010 top is spring loaded at the front, so it just presses down on front. On the 08 model, there are no springs, and they have retainer clips that you put into the door surround - just like you do with the bottom of the windows on the lip of the body tub.
SO, you CAN put a 2008 soft top on your 2010, BUT, you need to have the 2008 door surrounds to go with it.
Hope that helps.
Old Mar 2, 2011 | 05:55 PM
RLW007's Avatar
When I changed my 2010 soft top for a Mopar Sunbonnet I had to get new 2009 door surrounds to fit it. Sounds like the 2010 soft top is different.
Old Mar 3, 2011 | 06:11 AM
forgive me.......but what are door surrounds?
Old Mar 3, 2011 | 06:16 AM
Mark Doiron's Avatar
The plastic frames that go partway around the doors. The softtop attaches to them. Sometimes they are called door frames or door rails.
Old Mar 3, 2011 | 06:19 AM
Daves11JK's Avatar
Door surrounds pic
Old Mar 3, 2011 | 06:20 AM
Thanks! So will 2008 doors surrounds attach to a 2010?? Or is this just a huge pain the azz. Should I just hold out and try and find a 2010 soft top?
Old Mar 3, 2011 | 07:42 PM
curtise's Avatar
Sorry for the confusion.
A 2008 soft top WITH the 2008 door surrounds WILL fit on your 2010 Jeep
OR
A 2010 soft top WITH the 2010 door surrounds WILL fit on your 2010 Jeep.
You just can't mix and match door surrounds and soft tops from different years.
Old Mar 3, 2011 | 08:17 PM
Jkmedic231's Avatar
How long are soft tops typically good for?
This is my first convertible vehicle, so I was curious, 07 2dr sahara
Old Mar 3, 2011 | 08:41 PM
OR
Thanks! That clears it up for me.
