5.13 Gear oil....
So after a horrible experience... Shearing a rear pinion gear, axle leaks, no car for a week etc... I finally got it right! I have completed the break in period and I need to change the oil from what I hear. Should I still use the 75w90 like my manual states? or should I go with a heavier weight? What are yall running? BTW this is my dailly driver and it does alot of long trips on the highway if that matters. Thnx
For break in I used a conventional oil... not sure what weight, the shop that installed my gears put it in for me.
After about 700 miles they inspected thing, and I brought my own 75W-140 Mobil 1 for them to fill it with. I've been running 75W-140 Mobil 1 ever since
If you are just wheeling you’re not constantly pulling on the gears like you do when you are towing. I’m sure you can get into some circumstances where you add pressure to the gears, but not like you do when you are towing a couple thousand pounds or more over longer distances - including up hill.
Another note. The 140 will get a little hotter than the 90 when driving. The extra heat doesn’t help anything, but if you are towing you need the extra protection from the added pressure so you have to use 140.
When I got my 5.38s I verified what oil to use with the owner of the shop. He said the same thing - towing use the 140, otherwise stick with the 90. The Owners Manual says the same thing.
The 140 is thicker, so when you put that added pressure on the gears when you are towing you keep oil between the metal (because the thicker oil will take more pressure before allowing the metal surfaces to rub).
Thats some really good information. I guess I've been running the "wrong" oil for my circumstance, as I NEVER tow. Next oil change I'll switch it out, especially with summer approaching.
