Bedlining top inside/and out. Questions
Old Mar 29, 2011 | 08:34 AM
cyclone.1983's Avatar
Default Bedlining top inside/and out. Questions
Going to bedline inside and outside of my top w/ spray can bedliner. Going to do the inside first and then flip it over and do the outside. I think im going to use the Duplicolor as Ive found while searching that most people have success w/ it.
Couple of questions, how many coats for the inside? How many for outside?
How long does it take each coat to dry? I will be doing this in a heated shop if that helps.
Do I just use regular wood sandpaper to rough it up and then rub it w/ some rubbing alcohol?
Thanks for any input.
Old Mar 29, 2011 | 12:30 PM
Originally Posted by Alien10
Definitely don't use wood type sandpaper. I would use a red scotchbrite pad to scuff the surfaces followed by a wax/grease remover. As far as drying times, its all printed ok the back of the duplicolor can.
Thanks for the advice, thats why I ask as I have a tendancy to do stupid things! Anyone else have dos and donts?
Old Mar 29, 2011 | 02:12 PM
rozzman10's Avatar
Default inside.
i only painted the inside of my top.. and used the duplicolor truck bed liner.. i just used a piece of sand paper and roughed up the inside then wiped it clean with a rag and water.. let it dry.. taped off my windows with newpaper and frogtape (awesome stuff) then sprayed it down! one coat! if it scuffs off just touch it up.. very simple and cheap
Old Mar 29, 2011 | 03:17 PM
915RUBICON's Avatar
Yeah did mine this past weekend. So far looks great.
ID:	143435   Click image for larger version
ID:	143436   Click image for larger version
Old Mar 29, 2011 | 03:30 PM
Otari's Avatar
this is a cool idea....it takes that inside-of-a-cooler look away
Old Mar 29, 2011 | 03:35 PM
speakman's Avatar
Love JK forum logo. I was wanting to do the inside of mine, but wasn't too sure I wanted all black. I now have some great inspiration.
Old Mar 29, 2011 | 03:37 PM
4lo n go's Avatar
I understand the rest of the country might still be cold, but here in Florida it's getting hot already. Any changes in cabin temp thanks to this? Thanks
Old Mar 29, 2011 | 03:59 PM
Uafan's Avatar
That JK logo looks really good - also curious as to the temp.
Old Mar 29, 2011 | 05:22 PM
915RUBICON's Avatar
Hell if its that hot the top is off any way.....most of the summer it's the bikini baby
Old Apr 8, 2011 | 12:09 PM
rozzman10's Avatar
the JK logo is exaclty 5x the size of the JK sticker.. and i believe its at about a 30degree on the top.. just gotta take your time to get it just right
i havent noticed any changes in temp. i do believe that this wont change anything since it is in the inside of the top.. and my top is also off when the temp is up that high haha
