Break in for new gearing?
Old May 9, 2011 | 07:12 AM
xprider's Avatar
Default Break in for new gearing?
Recently had 5.38 gearing installed in my JKU Rubicon is there a break-in procedure to follow with new gearing?
Old May 9, 2011 | 07:21 AM
wayoflife's Avatar
JK-Forum Founder
1. go real easy on the gas and drive your jeep unloaded for about 15 to 20 miles.
2. stop and let your gears cool completely.
3. try to drive nice and easy for about the next 250-500 miles and then change out your gear oil.
Old May 9, 2011 | 07:26 AM
robsjeep9's Avatar
JK-Forum Ambassador
Is it ok to get on the hiway right after??
Old May 9, 2011 | 07:29 AM
wayoflife's Avatar
JK-Forum Founder
sure, just follow the steps above.
Old May 9, 2011 | 08:10 AM
robsjeep9's Avatar
JK-Forum Ambassador
Thank you..... I'm getting regeared on May 25th ..... I'm no handy man/mechanic can anybody including myself change the gear oil??? Or should I get a shop to do it? Is it an expensive job? Thank you ... AGAIN
Old May 9, 2011 | 08:19 AM
gamble3527's Avatar
this is solid to know, im dropping my jeep off tomorrow to have 5.13's installed
Old May 9, 2011 | 08:44 AM
Bosox5's Avatar
Veteran: Coast Guard
Its very easy, as simple as removing the drain bolt and letting the oil out then putting the drain bolt back on and then add new fluid. done.
http://project-jk.com/jeep-jk-write-...hange-write-up
Old May 9, 2011 | 08:45 AM
Bosox5's Avatar
you're going to love the 5.13s! i know i love mine.
Old May 9, 2011 | 09:00 AM
Mark Doiron's Avatar
Avoid cruise control; vary your speed occasionally.
Old May 9, 2011 | 09:03 AM
Rockroaster's Avatar
Putting 5.13 in mine this weekend with a buddy of mine up in Ohio. Hoping everything goes well as I have a 550 mile trip back home afterwards. Anyone think that far of a drive will be an issue, the day after they are installed? Will drive about 20 miles before hand to test them out.
