Trackbar Issue
Old May 11, 2011 | 11:46 AM
Monte417's Avatar
Default Trackbar Issue
I have a JKS front adjustable trackbar that has a jamnut that continues to come loose no matter how tight I make it. Anyone know why this is happening or does is this happening to anyone else? The same thing happens on my Rough Country front lower control arm jamnuts. What are the negative effects of thes loose jamnuts on the threads of the trackbar and control arms? Again everything was tightened pretty significantly when installed. Thanks
Old May 11, 2011 | 11:48 AM
murdoc319's Avatar
i've got one but its tight as far as i know, how long have u had it on? im only at a couple hundred miles with it so far
Old May 11, 2011 | 11:51 AM
Monte417's Avatar
8000 miles
Old May 11, 2011 | 12:01 PM
JKDon's Avatar
I have the same parts on mine with no loosening at all. Tap your wrench with a hammer after you get it tight, or use a longer wrench.
Old May 11, 2011 | 01:57 PM
Flaxbourton's Avatar
Originally Posted by FFA_nsk
It doesn't realy matter if it cones lose cause the while controll arm or track bar has to spin to make an adjustment. Clean the threads with some soap and a toothbrush to get all the grease off than put some blue loc tight and tighten it back down. Blue so if you need to make an adjustment it will be easier to get off .
I was going to suggest more or less the same thing. A little blue loctight should keep from backing off but keep it relatively accessible if you need future adjustments.
Old May 11, 2011 | 02:01 PM
mkjeep's Avatar
I've used a stuff called Automotive Goop (think thats the name, not at my house right now) Never had a jamnut loosen with it, plus, you can peel it off if future adjustments need to be made.
Edit. Amazing automotive goop is the name.,
Old May 11, 2011 | 06:44 PM
brobbins67's Avatar
I use RED loctite. Do you want it to stay put or be easy to loosen?
Old May 11, 2011 | 06:46 PM
brobbins67's Avatar
I used this stuff to keep my front fender flares from flapping after they were trimmed. I've hit the passenger side heard enough to bend the support braket but the Goop held!! Very tough stuff.
Old May 12, 2011 | 05:13 AM
Monte417's Avatar
Thanks guys the loctite was going to be my next step. I guess my question is can I do any damage to the trackbar itself seeing that I am putting a lot of pressure on the threads. Im assuming the jamnut is suppose to absorb most of that force. If my jamnut keeps coming loose can it be related to other issues?
Old May 12, 2011 | 05:25 AM
mkjeep's Avatar
The jamnut will keep your threaded part of the bar from flexing in the hollow theaded part of the bar. I would either locktight it or goop it. If it loosens after that, your internal threads may be damaged or partially stripped from running with it loose.
