painting supsension components
Old May 13, 2011 | 03:42 PM
anadlas's Avatar
Default painting supsension components
Hey just curious what you guys have used to protect your suspension components? I'm starting to get a lot of surface rust and think since the weather is getting nice i'll jump down there and tackle that project.
Old May 13, 2011 | 03:51 PM
Markdsv's Avatar
Default undercoating
hi, same here, my jeep is not even 6m old. I bought a rubbery paint called undercoating, basically a bitumen should be OK.....
any more thoughts?
Old May 13, 2011 | 04:20 PM
dcharge74's Avatar
Joe @ Teraflex suggested hammerite paint to me a while back. You should be able to get it at Home Cheapot or Blowes.
Old May 13, 2011 | 07:59 PM
robsjeep9's Avatar
JK-Forum Ambassador
Do you guys in the States have
Krown Rust Control?????
Shouldn't that treatment every year work? Or not????
Old May 13, 2011 | 08:41 PM
jeeperjkjeeper's Avatar
that's what i use every year!
Old May 14, 2011 | 12:03 PM
anadlas's Avatar
cool, i'll have to look around here for that undercoating. How much dismantling did you guys have to do to paint the components, i jumped under there yesterday and i think i might be able to get most of it by just removing the tires?
Old May 14, 2011 | 01:53 PM
scotlandjk's Avatar
I am going to be using black hammerite on my JK this summer. The salt destroyed the underneath over winter, mine is an 07 build so has some pretty major rust at the minute
Shouldn't be too dull as I am also putting on a bunch of AEV things at the same time!
Old May 14, 2011 | 03:43 PM
anadlas's Avatar
yeah i was kinda annoyed at how much surface rust i already had from 2 kansas winters.
Old May 15, 2011 | 05:47 AM
pik's Avatar
pik
I ususlly buy WD-40 by the half gallon and spray the susp. and undercarrage with it; seems to work pretty good. It seems to allow grime and mud to "bead" off.
Old May 15, 2011 | 06:18 AM
Runewolf1973's Avatar
Is it even necessary to remove the tires to spray paint a few things under my Jeep? My coil springs, and some areas on the axle and suspension are a bit rusty. I just want to make it look nice if I decide to get a stubby bumper. Is there any areas that I should avoid specifically...where the paint might affect the components? I don't plan on going too crazy with it though, just a touch up.
