Air Dam
Old Jul 15, 2011 | 09:44 AM
fanatic's Avatar
Default Air Dam
How important is the little air dam under the front bumper? I rub a little at full lock when flexed, and am trying to decide if I should trim or remove. Any pics of trimmed ones?
Old Jul 15, 2011 | 09:49 AM
fsr402's Avatar
It just helps kick the air under the jeep. Gives it a smoother entry instead of it slamming into the axle and stuff under there. You "may" notice a loss in MPG.
Old Jul 15, 2011 | 09:54 AM
wittys-jk's Avatar
Remove it. It looks better and you won't rub anymore. The loss in MPG is minimal if any at all. Worse case scenario you keep it and put it back on if you have any regrets.
Old Jul 15, 2011 | 10:03 AM
MancationJEEP's Avatar
you may notice hood flutter without it. keep that in mind.
Old Jul 15, 2011 | 10:09 AM
fanatic's Avatar
Hood flutter? Explain.
Old Jul 15, 2011 | 10:21 AM
your hood will flutter...bounce up and down a little as you gain speed. the stock hood latches are pretty weak, there's alot of play there....the air damn deflects air down under the vehicle and away, if removed the air is then absorbed within... you can counter the flutter by purchasing daystar hood wranglers for $25.
Old Jul 15, 2011 | 10:27 AM
scamp_71's Avatar
toss that worthless piece of plastic in the trash! minimal function and looks awful in my opinion.
Old Jul 15, 2011 | 10:39 AM
Grognard's Avatar
falls off easy on the trail
Old Jul 15, 2011 | 10:47 AM
IcyFridge's Avatar
I ripped mine off and have not looked back at all.
Old Jul 15, 2011 | 10:52 AM
Synthetik's Avatar
You get hood flutter even with the air dam.
It's useless. Toss it.
