Pulling the Trigger on a Front Driveshaft -- Need some quick clarification...
Old Aug 20, 2011 | 11:16 PM
RN M OVR's Avatar
Default Pulling the Trigger on a Front Driveshaft -- Need some quick clarification...
I have a 2dr automatic (33's) with a 3" lift that netted more at 4" of lift. I am going to purchase the Wood's 1310 front driveshaft. Before I do, I have questions that need answers. Thanks!
1) The stock driveshaft, which spat out grease, hits the skid plate at even a slight droop. Won't the new shaft hit the skid plate too?
2) New shaft or not, should I cut out a notch in the skid plate to help the droop angle/contact, or is that not needed?
Any other tips, advice, and comments would be great!
Again, thank you!
Old Aug 20, 2011 | 11:31 PM
wildandwillin's Avatar
Yes it will hit and yes you should notch it out..
Old Aug 21, 2011 | 12:43 AM
DrtyJeepr's Avatar
I replaced mine with a Wood's also and it still hit the skid. I don't have it rubbing the tranny anymore, and a small notch in the skid solved my problem. I only notched the front lip of the skid. Don't have any pictures at the moment though sorry.
Old Aug 21, 2011 | 09:40 AM
RN M OVR's Avatar
Thanks for all of your help. I have extended bumpstops in both the front and rear that should hopefully help with the too much articulation -- 33's with 4" of lift is nuts! But okay, so I should definitely cut a notch in my skid plate. Just around the lip? Any pics would be great. I think I have a rough image on how it'll all look.
Thanks!
Old Aug 21, 2011 | 02:32 PM
DrtyJeepr's Avatar
Here's mine. I trimmed some off that lower part also. I wasn't sure if it would hit there or not after the upper crossmember part was trimmed. You can see the line on my driveshaft where it was rubbing. I painted part of the line with a yellow paint marker so I could see if it was still hitting. It's on the top side of the driveshaft, you can't see it in this pic, but no rubbing so far. I also have the Teraflex extended bump stops. To measure the cut, I just kinda eyeballed it with the skid on and marked it with a paint stick.
