can caster issues cause death wobble?
Old Aug 23, 2011 | 06:56 AM
Olean NY Jeeper's Avatar
I just put new coils on my jeep. Clayton 3.5. Initially I put on a one inch spacer up front up front for winch weight compensation. This gave me over 5 inchs of lift up front. I did the lift proper. Loosened entire front end all control arms trackbars. Torqued on ground to factory specs. HORRIBLE DEATH WOBBLE. I checked everthing. All bushings good. All torque amounts proper. Checked drag link and tie rod. Everythng good. I remove one inch coil and it id much better. I have stock front arms. Could the crazy caster numbers cause this alone or us there something else off somewhere?
Old Aug 23, 2011 | 07:04 AM
rhinonemec's Avatar
I think you're going to have to do new arms, at least lowers. I did a 2.5 inch lift with a 1 inch coil spacer, and I ended up having to get an adjustable front tract bar and lower control arms.
Old Aug 23, 2011 | 07:06 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Death wobble isn't usually caused by a single issue. It's usually a compilation of a few problems. That said, the minimal caster angle of a stock JK gets worse, as you've discovered, when you lift it without using adjustable control arms. Poor caster angles increase death wobble tendency.
Old Aug 23, 2011 | 07:07 AM
IcyFridge's Avatar
Check your bolt torques first?
Old Aug 23, 2011 | 07:28 AM
Yea. I am def gettin new arms but I will b a couple months bfore I have the cash. Just wondering how caster plays into Dw.
Old Aug 23, 2011 | 07:33 AM
Can I just get lower arms and skip uppers to get a better caster angle? How much longer do I set them than stock with 4.25 inched of lift up front?
Old Aug 23, 2011 | 07:55 AM
mkjeep's Avatar
You can get just the lowers, most set theirs at 23-23 1/8 in eye to eye as as starting point.
In effect when lifting a vehicle and leaving the stock arms on, you are pulling both axles closer together under your jeep. Chances for DW increase the higher you go especially with a shorter wheelbase such as a 2dr. Once you start getting DW, the more it happens, the more probs/wear you'll have on other parts.
You may be able to adjust your toe out alittle see if it helps till you get your arms.
Old Aug 23, 2011 | 07:56 AM
Andrew@EVOMFG's Avatar
EVO MFG Representative
Yes you just need front lower control arms to adjust your castor.
23" is usually a good starting point with that lift height.
The EVOs can be adjusted while staying fully installed on your JK to fine tune the castor. No removal of one end required to adjust the length.
Old Aug 23, 2011 | 08:20 AM
I just put an angle finder on my lower c. 0 deegrees. I assume thats bad.
Old Aug 23, 2011 | 08:23 AM
nthinuf's Avatar
How are the angles on the trackbar and draglink? Compare to TF's video:
http://rides.webshots.com/video/3016...02496289IjoMUo
With 5" of lift, you should be looking at a flip also.
