How to clean bedlined rims?
Old Sep 5, 2011 | 11:42 AM
CajunJeeper's Avatar
Default How to clean bedlined rims?
Normally soap and water does the trick, but my jeep got kinda dirty this weekend with all the rain (and "accidentally" turning down dirt roads to have a little fun getting dirty). Does normal rim cleaner work with bedlined rims? Don't want to try, and it ruin them...
The pic was taken after I tried soap, water, and a brush.
Old Sep 5, 2011 | 11:49 AM
slinky's Avatar
I would try simple green and a green scotch brite pad. When I used to race dirt bikes, the simple green practically melted the dirt off of everything, and I used the scotch brite to get the stains out of the bare aluminum frame. Just use a little pressure, don't lean into it.
Old Sep 5, 2011 | 11:51 AM
Would purple power work just as good? Don't have simple green
Old Sep 5, 2011 | 12:12 PM
nthinuf's Avatar
Old Sep 5, 2011 | 01:08 PM
Simple green is a lot stronger than purple power, but yeah......it looks like you're due for another coat of bedliner.
I just did it two months ago!
Those lite spots are all the dirt/sand!
Old Sep 5, 2011 | 01:36 PM
ZMagic97's Avatar
Ever try citrus cleaners? I used it on all sorts of stuff for oils, dirt, etc and does the job but never ruins anything from my experience.
Old Sep 6, 2011 | 12:54 AM
budtest's Avatar
Armorall works great
Old Sep 10, 2011 | 02:25 PM
slinky's Avatar
Originally Posted by Kevlarjk
Ok ummmm. I can tell u from experience of being a dealer of professional Bedliners and over five years of spraying professional Bedliners that all these purple cleaners and harsh chemicals are gonna ruin the finish. Yeah it looks good when u first spray it but anytime dirt comes in contact with a pore type surface like Bedliner, it's gonna find any little spot to Bury itself in and u will never get it clean. Hints why I haven't bedlined my grill or wheels. I'm honestly surprised none of u have experienced an off weight wheel because depending on how much u spray it can get heavy. Back on subject. The best advice I can give u is use a back to black cleaner or a nice satin black rattle can spray paint. These will get ur finish back but this will only temporarily solve ur problem. And yes spray paint will stick to Bedliner and will last longer than back to black cleaners but u will eventually have to re spray them. Just my 2 cents.
This is in no way an argument against what you're saying, because you're right, but I used to dump concentrated simple green in the bed of my ram and scrub it with a stiff bristle brush to get the dirt and oil from my dirt bikes off of the bed liner. After 4 years of doing this, the sun did more damage than I did with the simple green, which was nil.
