Are you horny?
I mean what horn do you have?
I just replaced my stock horn with a Wolo Bad Boy air horn...
.amazon.com/Wolo-Model-419-Black-Design/dp/B000F5DQWY[/url]
... and I was half expecting it to blow my hood off. But it's kinda underwhelming. It is a few octaves higher in tone and seems louder but it's no tractor trailer horn by a long shot. The reviews on Amazon.com for this horn were good which swayed me to buy it. But with it installed, I'm not sure I like it.
So instead of trusting mass-market review, I'm going to a reliable source: jk-forum members!
What horn are you using? Is it loud and do you like it?
It's a straight stock wiring. I have the relay still. Maybe I'll try that instead. Can it be somehow linked to the steering wheel honker? From all I read, everyone has it wired to a dedicated separate switch.
Poked around a little and found this link...
https://www.jk-forum.com/forums/show...highlight=horn
Gonna try using the relay tonight and wiring 8 gauge line to the horn. The stronger power directly from the battery should do the trick
Thanks WhosUrBuddie for the tip! Will update with results (if I don't go deaf after the post-wiring test-honk
