Bedline
Old Nov 28, 2011 | 05:19 AM
stewartkaye2's Avatar
Default Bedline
Okay. I'm very close to stripping my 2008 jk carpet and interior and bedlining the tub. Do y'all have any pros/cons of this mod? Any advice will be highly appreciated. Also. I could either take a 2
Hour drive to the nearest rhino line place for them to rhino it. Or drive to a line x place in town. Rhino -500$. Line x -650$
What should I use/do?
Thanks
Old Nov 28, 2011 | 05:39 AM
Thanks for the advice. Is Herculiner a good product you think?
Old Nov 28, 2011 | 05:49 AM
jeep2007's Avatar
Herculiner is good as long as the prep is done correctly. My JK is Line x and prefer it over anything else and have had other Jeeps with it as well.
There are other options like Raptor and Rhino. Hopefully you hear from others but there are a few threads on your question.
Old Nov 28, 2011 | 06:54 AM
texwillys's Avatar
Check out this thread:
https://www.jk-forum.com/forums/show...eep-Water-Blue
Very nice results!!
HighCountryJeeper's Avatar
I am getting my 08 tub line-x'd in the summer. Ive done a lot of research and line-x seems to be the best product. Just like Rhino it can be touched up at any installer around the country for free under warranty. The biggest issue is doing the prep. If you want to save money you can prep it yourself by removing all the carpet, trim, seats and sound deadener. For any screw/bolt holes you want to reuse you need to put some disposable cheap screws/bolts in them for when they spray it or else they will spray into the threaded holes. Also think about what exactly you want bedlined, I am going to have them do the top rail (where the hardtop sits on) to give extra protection when I'm throwing stuff in.
Old Nov 28, 2011 | 06:55 AM
Croce's Avatar
I didnt wanna pay $500+ for bedliner, so i took everything out myself. taped it all up, sanded it and removed the heat shielding and sprayed it with Rustoleum bed liner. Been over a year and still holding up great
ID:	242849   Click image for larger version
ID:	242850   Click image for larger version
ID:	242851   Click image for larger version
ID:	242852   Click image for larger version
Old Nov 28, 2011 | 12:27 PM
abok's Avatar
Default Bedline
Try Speedliner. That thing is strong like hell and you have full pallet of colours. I have it on my pickup bed and works great
Sent from my BlackBerry 9900 using Tapatalk
