Steering stabilizer question
Ow long do these last and how do you know when they are shot? My JKU has just over 36k and is a 2008. The steering is a little...loose perhaps. I have never had a SFA which is why I ask. Thanks all.
Your steering being loose probably doesn't have anything to do with the SS. As for how long they last, I can't give you a definitive answer. Easiest way to tell if it's bad is if it's leaking. Or, take it off and see how difficult or easy it is to compress.. If its easy with little resistance, it's probably shot. If its got some resistance and can here the compression, it's still good. Hope this helps....
I have an '07 with 56K miles and just took mine off to put heavy duty one on for my bigger wheels/tires setup. The stock one was still ok, so I doubt yours is bad. I would however check it like what was said above to be sure.
I am on my 5th one in 3 years, plus the factory. Iv done stock, pro comp, teraflex x2, and now Im on my fifth....tried a Rancho this time. O'Rielys parts store here in town will warranty them for life with the receipt.
Have only smashed one..all the rest have just started leaking like a siv after about 8 months or so.........IMO they are all junk
