SRC side armor smittybilt mounting
Old Jan 11, 2012 | 07:47 AM
FrankCastle01's Avatar
Default SRC side armor smittybilt mounting
I got a pair of the side armor from ebay land and it came with no instruction and no bolts. Am I to use the factory bolts or am I missing some parts and need to hit the hardware store?
Old Jan 11, 2012 | 10:32 PM
Bump
Old Jan 12, 2012 | 05:24 AM
evancise's Avatar
I am about to try to put mine on today. You don't need any hardware. You take the two nuts to the side of the main body mount bolt off at both the front and rear body mount. Slide the armor on and put the nuts back. You can probably find the directions on the Smittybilt site.
Since they've already been on a JK yours might actually just go on. Many have fit issues (mine do) and I'll need to enlarge the front most bolt hole. There are several threads here about installation and issues with these. Good luck!
Old Jan 12, 2012 | 10:05 AM
Awesome.. Thank you.. Its too bad they have issues because they are the best looking in the bunch IMO.
Old Jan 12, 2012 | 05:42 PM
Yes I had to drill out the front most hole.. They look great but go ahead and plan on a drill for the install
Old Jan 12, 2012 | 05:59 PM
gadget799's Avatar
SRC Install insttructions--->
4 Door
http://www.quadratec.com/Assets/Installation/112143.pdf
2 door
http://www.quadratec.com/Assets/Installation/112142.pdf
Old Jan 14, 2012 | 04:56 PM
OleBC's Avatar
Can you use these with a body lift since they use the body mounts? Just ordered them and didn't even think about that
Old Jan 14, 2012 | 04:59 PM
gadget799's Avatar
Don't see why not .. these mount underneath the body to frame mounts, and the body lift spacers are above and the spaces come with extended hardware so all should work out
Old Jan 14, 2012 | 05:23 PM
OleBC's Avatar
Thanks for the info!
Old Jan 14, 2012 | 05:27 PM
gadget799's Avatar
No Problem .. hope it all goes together for you..
