Lurching when getting on and off the gas?
Old Feb 13, 2012 | 10:30 AM
HuntNFish's Avatar
Default Lurching when getting on and off the gas?
Hi Guys,
Newbie here, only had the JK for about a month now. Basic details: 2007 with a 3" lift, 35's, 4.56's, manual.
Just started to have an issue today where, when I go totally off the gas, or ease on the gas, the Jeep gives a bit of a lurch and makes a slight clunk. She continues to cruise after getting off/on the gas, but its not smooth.
When I ease back on the gas, it makes a squeaking sound that goes away when you push the throttle a bit more. The lurch has me concerned, and I am not too sure where I should start looking for issues, any ideas?
Thanks in advance.
Alex
Old Feb 13, 2012 | 10:34 AM
JeepRubi11's Avatar
Hey man welcome aboard. Pics of the jeep would be nice. Sorry cant help with the problem your having, but I'm pretty sure someone will be able to.
Old Feb 13, 2012 | 11:01 AM
rays0852's Avatar
Guys...lets try and help him out.
Sounds to me like its drive train related.
Could it be Drive shaft related? With that much lift I am thinking it could be an issue.
Get under your Jeep....look at the front and rear DS and see if there is any issues with the u joints or CV boots. Also check for fluid leaks around the axles and diffs.
Old Feb 13, 2012 | 11:03 AM
JKAbomb's Avatar
I have a similar issue with my 07 Sahara with manual. After I installed 3.5 series II it seemed to have started. I run 33" tires and stock driver shafts. Front is slinging a bit of grease but not making any noise. Clutch acting a bit strange and TOB making noise. Wonder if it related. Have 80000 miles on mine
Old Feb 13, 2012 | 12:21 PM
Blackmetal's Avatar
This happens to me as well, if I totally let go of the gas, my Jeep does the same thing. I have an 07 auto mostly stock except for the tires: 265/75R16
Old Feb 13, 2012 | 12:24 PM
IcyFridge's Avatar
Do you have a superchips?
Does this happen at all speeds?
What about reverse?
Maybe your back brakes are binding up?
Old Feb 13, 2012 | 12:49 PM
JKAbomb's Avatar
Its normally only during slow starts. I hit gas in first the let off and it starts bucking. Also makes a clank sound. Have to give it gas again to make it stop. All fluids are full and regularly changed.
Old Feb 13, 2012 | 12:50 PM
JKAbomb's Avatar
Also no superchips and breaks recently changed in back.
Old Feb 13, 2012 | 02:14 PM
JKAbomb's Avatar
It has been driving me crazy trying to figure out what is up with my Jeep. Any thoughts my fellow jeeprs
Old Feb 13, 2012 | 02:19 PM
1978cj7jk2012's Avatar
Might have some slack in your driveshafts due to improper angles??
