Swaying Jeep
Just finished getting a 3.5 inch rough country. I also installed 35/12.50/18 Nitto trails. First question is on the road is seems to sway a lot. What is the best way to resolve this. And next is it seems to be rough, no pun intended, when I'm on dirt roads. When dealing with the swaying could it be air pressure related. I have 38 lbs in each tire. Started with 45 and have been working down. The day after the lift was installed I drove out to south tx (400 miles) without any real problems. Maybe it just takes some getting used to. Just looking for opinions. Not an open window to bash what parts I have installed please. Thanks guys.
After you installed the lift, did you tighten the control arm and trackbar bolts while the jeep was on the ground or while it was jacked up/on stands?
and did you use the trackbar relocation bracket and drop pitman arm? or just an adjustable trackbar?
I took an expensive route and pieced it together: Rough Country 2.5" coils, added .5" spacer to front, 3/4" spacer to rear. Bilstein 5100 gas shocks. Warrior Products Front/rear lower control arms. RC adj front trackbar. Tera Flex HD axle mount rear trackbar bracket. RC front sway disco's. JKS rear sway links. Full Traction rear HD sway bar. Brake line extensions. etc...
I was really excited about getting my jeep lifted and looking good. I just want to fine tune some of the issuses im having. When i hit a bump i seem to feel it in the steering wheel. Like a hard hit not bumpsteer. IDK how to explain it. Ive heard several things like replacing my RC lowers with the relocation kit from AEV. ultimately i know its a jeep and its gonna drive like a jeep. New it didnt drive like a caddy but it was nice. I just want to fine tune it alittle here and there to make it so i can feel comfortable. Im getting alittle vibration getting to highway speeds but ill associate that to the RC 1.5 inch spacer i have for the stock wheels. Anyways im always looking for new ideas. I may try the FT HD swaybar kit. Seems like a fairly cheap fix for some swaying issuses.
