Front shock removal
Old Aug 14, 2012 | 03:01 PM
Cobra65's Avatar
Default Front shock removal
Guy's
I was looking over my 2012 Sport this morning and I have a question.I've removed and replaced shocks in the past and I was looking at the JK front shocks.How are the upper nuts removed?What has to be removed to access these nuts?
Thanks,
Vince
Old Aug 14, 2012 | 03:06 PM
aldaman's Avatar
The Driver's side is visible and accessible. However, the passenger side is a different story. Other members have cut a slit/dremmeled an opening to get to it. Another option but may take more effort is to remove the inner lining
Old Aug 14, 2012 | 03:09 PM
EzK's Avatar
EzK
I used a ratchet wrench(so useful) and channel locks to hold the shock.
Getting the new ones on was the hard part.
Old Aug 14, 2012 | 03:14 PM
stoneWhiteJK11's Avatar
16 mm wrench and trim plastic back a little. It has no effect on jeep cosmetic or functional
Old Aug 14, 2012 | 03:32 PM
Beau's Avatar
Rag and a vise grip on the upper part of the rod works pretty well
Old Aug 14, 2012 | 03:59 PM
kaptkrappy's Avatar
Originally Posted by Cobra65
Guy's
Thanks,
Vince
Like the others have said "cut that plastic crap out of the way". Well, they might not have said exactly that.
Name:	Right Front Spring 1.jpg
Old Aug 14, 2012 | 05:44 PM
OJK12's Avatar
I know I never understood why Chrysler liked their front shocks to have studs at one end it's a pain in the ass to remove them especially if you live in the rust belt. I always convert them over on my trucks and jeeps!!! Life will be so much better after you do!!
Old Aug 14, 2012 | 05:48 PM
AlphaRomeo15's Avatar
This is the way to go.... No need to cut or remove other parts, patience is the key
Old Sep 17, 2012 | 02:42 PM
kneeman's Avatar
The drivers side can be done like this
Please tell me how you can do the passenger side. You cannot get the wrench on the and have the wrench sticking out to hold it still while you turn the shock with vise grips so how do you do it?
Old Sep 17, 2012 | 03:18 PM
This is the type of wrench you need not a sockets. Make sure they are the ratcheting kind or you will bust your knuckles from taking the wrench on and off the nut. I don't remember what size you need.
