King Coilover Spacers Install
Old Sep 23, 2012 | 12:49 PM
inspect-a-home's Avatar
Default King Coilover Spacers Install
Installed AGM spacers on the 2.0 KING coilovers, what a difference. Noticed the stock spacers allowed alot of grinding and were not properly aligning the coils.
Test drive went well, no noise!, straighter coils, and actually slightly better ride. Worth the extra $$$. Definatley getting some for the rear coilovers as well.
Before Pictures:
Name:	king spacer.jpg
ID:	369604   Click image for larger version
Name:	king spacer 3.jpg
ID:	369605   Click image for larger version
Name:	king spacer 2.jpg
ID:	369606   Click image for larger version
Name:	king spacer 4.jpg
Old Sep 23, 2012 | 12:53 PM
After Pictures:
Name:	king spacer 5.jpg
ID:	369610   Click image for larger version
Name:	10 inch 150 coils.jpg
ID:	369619   Click image for larger version
Old Sep 23, 2012 | 03:09 PM
Powderburn's Avatar
Was the original space from king?
Old Sep 23, 2012 | 03:29 PM
The last one on the before pictures is the POS original blue spacers.
Old Sep 23, 2012 | 04:05 PM
Sommer13's Avatar
Damn man, they didn't look that off when I saw em up close in Luling, now I really see it. Nice fix, how much the spacers go for?
Old Sep 23, 2012 | 04:59 PM
Dude, you should here the stock spacers off roading. Really noticed them when slow crawling...everyone says they're normal, but I knew the shock bodies wouldnt last long with all that grinding, binding, and rubbing. The ride got a little smoother as well, guess straighter coils help. The AGM spacers go for $200 (1 set only). Now, gotta go on a Raman noodle diet for a week to get the rears matched!
Old Sep 23, 2012 | 05:19 PM
jamgolf's Avatar
I just got the evo lever kit as well and there is quite a bit of noise when hitting bumps and dips on the road. I suppose this is the fix?
How difficult is it to install these?
How big of a difference is there in noise? Is it completely gone or somewhat less than before?
Old Sep 23, 2012 | 07:16 PM
The Evo lever does not utilize two springs, so these spacers would not help your application, but the fronts EVO coil overs do
The noise, grinding, clicks, binding in general went away..almost totally! I dont even notice anything up front anymore.
The installation is fairly easy, I did one side at a time. First remove swya bar links or unlock your sway bar. Next I just release compression preload on the springs by moving the adjusters all the way up, drop axles, only removed bottom shock from mounts, remove spring retaining cups and drop the springs, and replaced spacers. Took about 1 hour up front. Good luck
Old Sep 23, 2012 | 07:22 PM
Just looked on EVOs website, they have a picture with a Jeep with red coilovers and It has dual rate springs, so if your application is similar to this you should be able to install aftermarket spacers. Maybe EVO can chime in
Old Sep 24, 2012 | 03:38 AM
jamgolf's Avatar
Thanks for the information.
