Which track bar has 9/16" bolts?
Old Oct 4, 2012 | 12:38 PM
Flip94ta's Avatar
Default Which track bar has 9/16" bolts?
My stock bar is messed up and I'm looking for an upgraded aftermarket one. Which ones are 9/16" at both ends? My first choice was JKS but I've read that the frame end is 14mm now. Is ******* a good bet?
Long term goals are to level the front end(1") and true 33" tires. Thanks.
Old Oct 4, 2012 | 12:48 PM
Monte417's Avatar
I have the new jks trackbar and the 9/16 bolts fit just fine at both ends
Old Oct 4, 2012 | 01:03 PM
rubiconjk09's Avatar
I have the teraflex track bar and the 9/16 bolts fit fine.
Old Oct 4, 2012 | 01:06 PM
Dagley918's Avatar
I can confirm this, freshly installed this morning and mounted with the Grade 8 bolt upgrade via Northridge.
Old Oct 4, 2012 | 03:09 PM
c17loadmaster's Avatar
Ive got the Rock Krawler Bomb Proof trackbar and it is 9/16 on both ends.
Old Oct 4, 2012 | 04:50 PM
smittycm's Avatar
Veteran: Marine Corp
My Rock Krawler LCA's are 14mm on the axle end. Maybe that's what you were referring to.
Old Oct 5, 2012 | 01:38 AM
Flip94ta's Avatar
No, I'm talking track bars. Thanks for the info guys.
Old Oct 5, 2012 | 03:34 PM
Flip94ta's Avatar
I ended up ordering a JKS and a bolt kit from Northridge. The Rock Krawler showed a minimum 2 inch lift since its my commuter I'm never going that high. I appreciate everyone's input.
Old Oct 9, 2012 | 07:48 AM
Jeep757's Avatar
You should check if you have a local bolt store that sells the grade 8 9/16th bolts. I went to a local store here and got the exact same bolts/nuts/washers and only paid $22.00(after tax). Alot better that paying $80+shipping.
