Connecting Axle breathers to intake snorkel
Ok, sounds crazy i know, but hear me out. the highest i have seen people mount their axle breather hoses is on the firewall inside the engine bay. to me that still seems like water could splash up there. if you had a snorkel you could thread some fitings into it for your axle breathers, probably before the pvc return so your not getting dirty engine oil in your axles, then all you would have to worry about would be keeping your intake above water level. what do you guys think?
Its never been done that i know off, and i wouldn't suggest doing it. But it you want to try something, I've put baby bottle nipples on the vent tubes, lets the air pressure that can build up in differentials out without letting water in.
Yes. The snorkel is bound to be a lower pressure than inside the diffs. A slight vacuum in the diffs can cause water to pass through the seals.
The whole idea of the vent tubes is to keep the diffs at an equal pressure with atmosphere.
What about just mounting it high up and add in a check valve that allows it to vent, but doesn't allow anything to flow in? We use them on our dirt bike gas cap vents. They also make splash guards for the top of them, but they serve a slightly different purpose.
Just like your intake, you could route your vent through a reservoir that would catch small amounts of water. A good example is also a radiator overflow or a brake line bleeder. Any liquid is caught in a tank, but air still flows through connections in the top.
One of the vent tubes already ties into the stock air box, so yeah no need to worry about a vacuum sucking fluid out. Several people, including myself run breather tube extensions that tie all of them together into this one vent line. I think river raider sales a kit for them. Search breather tube extension and you should find some options.
Sent from my EVO using Tapatalk 2
The final line, after all the other lines are tied together, is connected to the line that goes from the stock air box to the right side valve cover. That's the line that feeds the crank case with filtered air for the PCV system.
I wouldn't want to have contaminated diff/transmission/t-case oil getting into my crank case. (Or into the air box or snorkel, if connected to one of those)
And like I said, drawing a vacuum on the gear boxes can promote water and dirt migration through the seals.
Seems to me like a bad idea.
