wet sanding???
Old Dec 22, 2012 | 05:26 AM
fctyson0's Avatar
Default wet sanding???
hello everyone i am in the process of priming and painting my poison spyder front bumper and wanted opinions on wet sanding between coats of pain.i was thinking 600 grit would be ok.
Old Dec 22, 2012 | 05:39 AM
H00LIGAN's Avatar
I don't wetsand until completely done and even then, I only wetsand the clear.
Sent & misspelled from my MB860 using predictive text & Tapatalk 2.
Old Dec 22, 2012 | 07:55 AM
fctyson0's Avatar
So you're saying I don't need to sand at all between coats?by the way I am using a rattle can
Old Dec 22, 2012 | 08:04 AM
Rich6700's Avatar
Why bother, it's a bumper and only gonna get rusty anyway. Paint it with some textured paint and be done with it. But if you must lay down 3 coats of paint let it dry for a day, then hit it with a 1000 grit paper.
Old Dec 22, 2012 | 08:17 AM
PsychoCupcake's Avatar
I'm painting mine this weekend too. And yes, I wet sanded with 600. Mostly it was to fix a fingernail scratch I left in it from touching it before it was dry. But the wet sanding will help with the finish.
Pic is after wet sanding before final coat.
Old Dec 22, 2012 | 08:45 AM
fctyson0's Avatar
To wet sand do u just wet the paper?
Old Dec 22, 2012 | 08:47 AM
fctyson0's Avatar
And do I do it each coat or just before final coat
Old Dec 22, 2012 | 08:50 AM
JKingAround's Avatar
Use a spray bottle and keep the area wet.
Old Dec 22, 2012 | 08:51 AM
No you don't do every coat
