2.5" lift gains 3.5" is this right?
Old Jan 19, 2013 | 05:37 PM
scratchkenny's Avatar
Default 2.5" lift gains 3.5" is this right?
I just got done installing my 2.5" RC lift on my 2 door. I gained 3.5". I now there will be some settling but I didnt think it would be 1" . Is this right?
Old Jan 19, 2013 | 06:04 PM
rockyjk07's Avatar
Yup they use the same springs on the 4 doors so they give the 2 doors more lift
Old Jan 19, 2013 | 06:14 PM
It will settle right? If it dont I guess i need to look into a new drive shaft right?
I hope it dont settle Its growing on me
Old Jan 19, 2013 | 07:10 PM
rockyjk07's Avatar
It shoud settle but i dont think it'll drop down too much and i would get a driveshaft sooner than later lol
Old Jan 19, 2013 | 07:19 PM
silversurfer575's Avatar
Value for $!! LoL!!
What size tires u running?
Run your stock DS for a while, but I would have recommended a DS upgrade anyway, even with a 2.5" lift on a 2 door. Kinda of a bummer, but at least you will be done with that upgrade.
I also have a 2 door, and did the TF 2.5 coil lift, but used the 4 door spec'd coils, plus I added a .5 spacer in the front and a 1 inch spacer in the rear. I upgraded my front and rear DS at the same time. I couldnt see spending money on tires, rims, lift, and everything else, and then risk tearing up my transfer case or something else if my DS was not right.
I know its not fun having to spend more $ on these unforeseen impacts, but your close to being done with the spend. I think the biggest part is the tires, rims, and lift.
Good luck with your build.
Old Jan 19, 2013 | 09:10 PM
justin22's Avatar
Do your rear ds first. But no need to rush out and do it right away. I got almost 2 years out of my rear before it started to act up.
I was running a 3.5" lift on my 2 door.
Old Jan 20, 2013 | 03:10 AM
Originally Posted by dojohnso
Value for $!! LoL!!
I am still useing the stock 255/75/17 that came on it. I got the lift at Christmas and was waiting to put it on till I could make up my mind on tires. I still aint made up my mind on tires so I went ahead and put the lift on. I guess I well will put my bumper, winch, and light bar on today, then all I have to do is find the tires I want.
Old Jan 20, 2013 | 11:58 AM
Ryan0260's Avatar
Yes it will settle. RC springs are known to sag over time anyways. I wouldn't worry about it
