2007 power steering reservoir cap leaking
Old Jan 20, 2013 | 08:22 AM
4wheels4life's Avatar
Default 2007 power steering reservoir cap leaking
Need some advise as to where to look or what to do. I am losing power steering fluid out of my reservoir. It is wet around the cap and is pooling up on the air box ribs beside it. There is also splatter or a blow pattern on the hood. I know the cap does not seem like it locks in place when tightened but then I have no idea as to how they feel when you tighten them down so it may be right. The cap has the o ring on the neck of the cap and I do not see any cracks anywhere. So any ideas as to what to look for?
Old Jan 20, 2013 | 08:28 AM
familytime's Avatar
JK Forum Regional Rep
You're not over filling the reservoir? Maybe the fluid is getting too hot
Old Jan 20, 2013 | 08:34 AM
jeeperjkjeeper's Avatar
are you sure it's not the rad cap....mine was bad and sprayed on the air cleaner box as well
Old Jan 20, 2013 | 11:21 AM
You know you may just be right. I just went back out and looked at closer and I can see residue under the cap. With the power steering reservoir right there I just jump at it right away.
