D30 Gusset and Sleeve kit recommendations...?
Old Jan 31, 2013 | 04:16 PM
MarbleheadGuy's Avatar
Default D30 Gusset and Sleeve kit recommendations...?
Looking to reinforce the old D30 now that I'm running 37s. Sleeves, gussets, anything else I should get? Don't want to spend a ton, but want the extra reinforcement. Any particular brands/kits you all recommend? Teraflex sleeve and gusset kit just includes upper yoke gussets. Is this enough or should I get top and bottom gussets?
Thanks
Old Jan 31, 2013 | 04:21 PM
Ryan0260's Avatar
Evo and Teraflex are good ones
Old Jan 31, 2013 | 04:34 PM
maine07jk's Avatar
I just did EVO gussets and an Artec truss on my D30 with EVO lower control arms skids.
https://www.jk-forum.com/forums/jk-w...thread-259387/
Old Jan 31, 2013 | 04:36 PM
mistasparkl's Avatar
I got the EVO gussets and LCA skids, and Nitro sleeves from northridge.
Old Jan 31, 2013 | 04:58 PM
pwain's Avatar
As long as they are properly installed any brand should suffice.
Old Jan 31, 2013 | 05:00 PM
maine07jk's Avatar
By the way, if your going to be there welding, why not do the bottom gusset as well.
Old Jan 31, 2013 | 05:03 PM
k0260's Avatar
I went with Synergy gussets and Nitro sleeves. Evo sleeves are stronger though and have a nice shaft seal, any weld in sleeves are stronger than 'pound in' sleeves. Gussets are pretty basic, any of the weld on gussets will work fine.
Old Jan 31, 2013 | 05:04 PM
Tripletsi's Avatar
X2, just ordered mine tonight.
Old Feb 4, 2013 | 11:42 AM
KG6SLC's Avatar
Default Sleeving vs Gussets
Sleeving reinforcement can be done in two ways. Internal sleeves are inserted into the axle housing and increase the "thickness" of the housing between the housing and the axle. Some manufactures of internal sleeves are: Rock-Slide Engineering, Poly Performance, Tereflex, Iron Rock, EVO, and Nitro. I believe all but the Nitro require holes to be drilled in the housing then plug welding the sleeve to the axle tubes. The Nitro is pressed/(pounded) into place using friction of a precision fit. Nitro sleeves are preferred by some as they have a slightly larger I.D (resulting in a thinner wall thickness) that is just large enough to allow use of 35 spline axles.
An alternate method is to sleeve the outside of the housing. Rock Slide Engineering has an outer sleeve kit. This increases the "thickness" of the axle tube by adding material to the external or outside of the tubing.
Gusseting is installed at least on the upper sections of the "C" where the "C" is the weakest. However, gussets can be installed on the lower section as well . There are two options for these. Solid flat (and thick) gussets are available through Rock Slide, Terraflex, JKS, and Pure Jeep. The other option is thinner gauge metal that is formed into a "U" shape and is welded in place on both sides of the "U" channel of the gusset to the outer edges of the "C" section. This style can be obtained through, Poly Performance, Iron Rock, Nitro, and EVO.. Some users have stated that part of the "U" section can interfere with the speed sensor (when the wheels are fully turned to the steering stop) while others have not experienced (or expressed) this.
Trusses (reinforce the entire axle tube assembly and are welded to the "pumkin" and typically to each side of the housing) are available from Pure Jeep and Artec.
The topic of how much reinforcement is enough has been discussed numerous times with almost as many opinions. However, all agree that running larger tires should include at least some reinforcement and how "extreme" you wheel should be taken into consideration. Obviously, if you haven't bent your axle you are OK. However, if you have bent it, the reinforcement installed was not enough.
KG6SLC aka Eugene
Old Feb 4, 2013 | 11:53 AM
maine07jk's Avatar
It was also mentioned when I was looking into doing my D30 not to upgrade the axle shafts unless you upgrade the gears as well. Now the week link is the axle shaft and when you upgrade the axle shafts your weak link is now the gears which are big money. Better to blow and replace the axle shaft than the gears.
