Running 33s with no lift
Old Feb 2, 2013 | 10:19 AM
wranglanator's Avatar
Default Running 33s with no lift
I'm sure this has been asked before but searching didn't come up with much. I've finally found a wheel and tire combo that I can afford and like. I'm looking at putting 16" Level 8 Guardians with a 285/75/r16 Cooper Discover ATP tire on a stock 2012 JK Sport. My big concern is rubbing or smacking the fender on a dip. Do I need to worry with this combo? I plan on lifting in later, I just can't stand the stock look any longer.
Old Feb 2, 2013 | 10:47 AM
Jonathan_JK's Avatar
its been done. You will rub at full lock. Unless you put a couple of washers to your steer stops. Also don't expect to go over anything more than a Mall speed bump because you will rub on your fender. And don't even think about disconnecting your fronts at all. Get some flat fenders, leveling kit or both and you will be somewhat ok.
Old Feb 2, 2013 | 10:50 AM
Most of it depends on your back spacing. You might rub on on LCA's too if the back spacing is not enough.
Old Feb 2, 2013 | 10:52 AM
hamrickac's Avatar
There are some people that run that size and have no rub and some that say they have rub at full flex. I don't know what the backspacing or offset is on your rims but if it is more than 4.75 you will probably need wheel spacers.
There is a sticky at the top that should help you more.
Old Feb 2, 2013 | 10:56 AM
HoldermanWV's Avatar
I run 33x12.50 cooper stt and stock rims with 1.5" wheel spacers it rubs at full flex sway bar disconnected only
