Limiting straps..
Old Mar 5, 2013 | 06:40 PM
Justinn407's Avatar
Default Limiting straps..
Does anyone here use em, any pros/cons, was thinking of getting a set to prevent any damage to my shocks.....idk
Old Mar 5, 2013 | 07:24 PM
Smashboogie 4x4's Avatar
Former Vendor
You will absolutely want to run limit straps. Running limit straps will take all of the load off of you shocks and let all the weight of the axle and wheels hang on the strap instead of the shock, drive shaft, brake lines, ABS wires, ect. They are very cheap insurance.
We highly recommend them and run them on our rigs.
Old Mar 5, 2013 | 07:49 PM
DannyMalkin's Avatar
Where do they attach? Just wondering.
Old Mar 5, 2013 | 07:55 PM
big dr's Avatar
bottom of frame to top of axle
ID:	430279   Click image for larger version
Old Mar 5, 2013 | 08:25 PM
Ncb's Avatar
Ncb
Is that bump stop rubbing the tire?
Old Mar 6, 2013 | 05:53 AM
Justinn407's Avatar
Is there any certain brand I should consider, and do these mount up in existing holes or will I have to fab it?
Old Mar 6, 2013 | 09:07 PM
big dr's Avatar
It doesn't rub at any point during the articulation,,,, even though it comes within about an 8th of an inch But yes,, it is a custom bump stop
Old Mar 6, 2013 | 09:11 PM
big dr's Avatar
In So Cal we have Makinsie's and Kar Tec,,, I'm sure there are others,, do a google search. Also,, do a good job of measuring your length,,, and know that for every 12" of strap, it will likely stretch 1 more inch. Good luck
Old Mar 7, 2013 | 03:42 AM
Justinn407's Avatar
Ok thanks for the tips, I'm goin to go take some measurements and go from there...
Old Mar 7, 2013 | 04:29 PM
Former Vendor
We use the Synergy limit straps. About $25 each.
