Optima Yellow top or Blue?
Old Mar 13, 2013 | 02:37 PM
Jonathan_JK's Avatar
Default Optima Yellow top or Blue?
So I'm trying to decide on a optima gel cell battery for my JK. So I go to the site and they want me to put in my model. Except there is no drop-down for 2013 and the 2012 drop-down does not have the wrangler listed.
I have to say optima needs to update their website. I'm sure the 2011 battery specs will work. Anyone think otherwise?
What do you guys think is a better battery? The yellow or Blue top?
Old Mar 13, 2013 | 02:54 PM
fishtale's Avatar
Neither. Go to Sears and get their Diehard Platinum.
Old Mar 13, 2013 | 03:07 PM
Are they gel cell?
I also hear AGM batteries are the best for running down and charging as well.
Old Mar 13, 2013 | 03:11 PM
Ryan0260's Avatar
Get the yellow top. The blue top is a marine battery.
Old Mar 13, 2013 | 03:19 PM
toolow262's Avatar
Veteran: Coast Guard
Without looking at the specs of the two I don't know off the top of my head if one is much better than the other. We run the blue tops in the Coast Guard but like said above thats a marine grade battery, may just be paying more for the "marine grade". Best is to look at the spec differences.
Old Mar 13, 2013 | 03:27 PM
I'm going with optima. We use them in our tugs on the flight line. We also use them on aircraft APU units. If there good enough to jump a Jet my money is on optima. We use the yellow. But I read somewhere that marine battery's have a deeper cycle better for lighting systems and winches
Old Mar 13, 2013 | 03:53 PM
oriffx's Avatar
Only two options worthwhile. Optima Yellow top or Sears Diehard Platinum. Both are very good.
Old Mar 13, 2013 | 04:37 PM
Swillbilly's Avatar
Any opinions on Odyssey batteries? Ran them in all of my ATV's and always had great luck.
Old Mar 13, 2013 | 04:50 PM
Ryan0260's Avatar
They are great batteries as well. Sears diehard batteries are rebranded Oddyseys, if that tells you anything.
Old Mar 13, 2013 | 04:54 PM
fishtale's Avatar
Marine batteries are designed to be run down to no charge and then charged to capacity. Not a good idea for a vehicle starting battery. Plenty of info on the WWW. Google is your friend.
