Wheel Spacers on 35s???
Old Mar 17, 2013 | 06:10 PM
2012 JK Beaver's Avatar
Default Wheel Spacers on 35s???
I have an OME 2.5 HD lift on a 2012 Rubicon.
When I got it I was thinking I was going to put 33s on it. I've changed my mind I'm going to go 35s. I would like to put the 35s on my stock rims. I'm pretty sure that I will need spacers to do that. Is this a bad idea? Is there anything else that I'm not seeing that will need to do.
ID:	435144   Click image for larger version
Old Mar 17, 2013 | 06:13 PM
Trugz's Avatar
Its perfectly fine. I have a 3.25 lift with stock tons on 315/70R17 and I wheel it often.
Old Mar 17, 2013 | 06:28 PM
k0260's Avatar
Yeah you're good to go. I also have 315's on 1.5 spacers that see regular abuse and hold up great.
Attachment 435156
Old Mar 17, 2013 | 07:10 PM
Sahara_Maverick's Avatar
I have been using the Spidertrax spacers for a few years with my 35s without any problems.
I had to use them because with the OEM 17in Rubi wheels the tires were rubbing on the frame. If you change the OEM rims for a model with adequate backspace the spacers will not be needed.
Old Mar 19, 2013 | 05:17 AM
Thank you for your input.
Old Mar 19, 2013 | 07:33 AM
hypeiv's Avatar
depending on the width of the tire you went with, you might have had to run spacers with 33's as well.
Old Mar 20, 2013 | 05:36 PM
I want 35s but I am not see how it is possible. I have the OEM tires and wheels 31s. I was under the belief that if I got this lift I could do 35s and that was a big selling point.
Old Mar 20, 2013 | 06:42 PM
cg07sut's Avatar
12jkb, you are going to have to trim the rail and probably the pinch weld behind it
Old Mar 20, 2013 | 07:20 PM
That is what I was afraid of.
