2dr vs. 4dr?
Old Mar 23, 2013 | 06:05 PM
PiratesFan's Avatar
Default 2dr vs. 4dr?
Ok prob a dumb question but I have a 2008 2 dr wrangle x with 2.5 terra flex level kit 32 x 12.5 17 wheels and tires steering stabilizer and brand new shocks... I bought this jeep in dec with some of this already done minus the shocks and stabilizer but my questions is my jeep rides rough as hell and i know its a jeep and that is the nature of the beast but i have never driven a stock 2 dr and have nothing to compare it too... I am mainly asking to make sure nothing is wrong with my rig rough ride or not I love my jeep and prob will never buy anything but a jeep again... But I drove a freind of mines 2010 stock 4 dr the other day and it rides like a Cadillac compared to mine and I know that it should because its longer wheel base an the 2dr have a really short wheel base but i just thought with all the upgrades mine would ride a little better than that?
Old Mar 23, 2013 | 06:07 PM
PiratesFan's Avatar
Also forgot to mention this is my first jeep ever and I'm new to the jeep world i owned a stock fj cruiser prior to this so I'm used to the short wheel base but the fj did ride smoother but i still like my jeep better feels a lot more stable on and off road...
Old Mar 23, 2013 | 06:14 PM
FDHog's Avatar
2 door rides a lot stiffer. Do you know if they are original shocks? Previous owner might have changed them with the lift.
Old Mar 23, 2013 | 06:15 PM
jaybrown's Avatar
It's the lift. It stiffing it up Hard springs. Mine stock was really smooth. I have a 4 inch lift and with the big knobby tires. It bounces and travels all over compared to stock
Old Mar 23, 2013 | 06:25 PM
Schlieko's Avatar
Default Lift Kit = Rough Ride
x2 on the lift. I have the 2010 JK Unlimited too. Stock, rode really smooth, especially with the stock tires. Once I put the lift on, it was a different Jeep. Have to keep a tight grip on it at all times. 35s + mud terrain tires made it rougher too. One thing that did seem to help was when I replaced all my steering components. The difference between stock and Currie was remarkable.
I also had a 2002 stock TJ with no lift and it rode smooth compared to what I have now. All that said... I would never go back. Beast rigs will never be tamed!
Old Mar 23, 2013 | 06:29 PM
nthinuf's Avatar
Let some air out of the tires?
My local tire shop likes to put my 35's up around 45psi, which is way too high.
Old Mar 23, 2013 | 06:36 PM
PiratesFan's Avatar
Thanks for the quik responses and glad to know there isn't anything wrong with my jeep and i would do it all over again i don't mind the ride for way better looks lol... And previous owner did replace the shocks with old man emu and the bushings fell out of both front with in a couple months of me owning and i put rancheros 9000xls on... But thanks for the info guys
Old Mar 23, 2013 | 07:29 PM
hypeiv's Avatar
good call on the tire psi... when I got my 35's the shop filled them to 45psi and it was beating me up on the road. I lowered them down to 30 and its much better.
Old Mar 23, 2013 | 08:55 PM
dahreno's Avatar
Don't just lower you tire pressure without looking to see the load range of your tires. I have 35 " tires on mine and the tires are load range E . E load range is basically for one ton trucks and will support a little under 4,000 pounds , each tire . My whole jeep weights about 4 , 000 pounds . I run the tires at 32 PSI , and it rides like a caddy . If any higher than that , it's like I have steel discs for tires !
Old Mar 23, 2013 | 09:15 PM
big dr's Avatar
Run your tires at 30 PSI , and get rid of the rancho 9000's,,, they are crap!,, go old man emu,, or if you really want performance, step up to the Fox 2.0 reservoir's. Good luck!
