Airing Down Tires
Old Apr 3, 2013 | 03:07 PM
JK Soldier's Avatar
Default Airing Down Tires
What tools or device does everyone use to air down their tires before hitting the trails? I have looked at a few from 4WD but would like some input on the good/bad on what is being used? Using a tire pressure gauge takes way to long.
Old Apr 3, 2013 | 03:21 PM
patricks99's Avatar
Veteran: Marine Corp
I use Teraflex tire deflaters as seen in the link, I had an issue with some teraflex brake lines and they sent a set of deflaters for free.
https://www.google.com/shopping/prod...ed=0CF0Q8wIwAQ
Just screwem on (tighter for a faster release, loose for a slower release)
Old Apr 3, 2013 | 05:08 PM
pxb006's Avatar
Old school. Screwdriver and tire pressure gauge.
Old Apr 3, 2013 | 05:19 PM
hypeiv's Avatar
I got a valve core removal kit that comes with extra valve cores
I unscrew the valve core and let the air rush out and replace it once it gets to about 18psi... I take it the rest of the way down using the little nippe on the back of my tire pressure guage.
Old Apr 3, 2013 | 05:24 PM
CDN-JK's Avatar
I do the same thing. Fastest way IMO. If you are good and used to doing it, you can drop it to 1 PSI above where you want it, then put the core back in and be right where you want it. Its that easy.
Old Apr 3, 2013 | 05:33 PM
Phrogmech46's Avatar
I have been using Staun deflators for the past couple of years. They have been great!
Old Apr 3, 2013 | 05:36 PM
Offroad_Elements's Avatar
Former Vendor
Staun II deflators... Best invention ever ...
Old Apr 3, 2013 | 06:16 PM
DadsCJ's Avatar
2nd this.......
Old Apr 3, 2013 | 06:25 PM
Murder¹'s Avatar
Currie tire deflator with built in gauge
Old Apr 3, 2013 | 06:57 PM
bbolander's Avatar
lock on air chuck with a 3" brass nipple for a handle, gauge with nib for fine tuning. never thought about making two of them and doing both tires on one side at a time, might do that!
