Rear Trackbar Clearance on 3" Teraflex
Old Jan 29, 2008 | 10:28 AM
Old_School's Avatar
Default Rear Trackbar Clearance on 3" Teraflex
I received my new right rear shock and shock relo bracket from Teraflex. Thanks Joe for the excellent customer service. As I stated on an other thread, I had clearance issues between my trackbar bracket and rear shock. The relo bracket fixes the clearance problem.
Here is my question. Can I use an aftermarket trackbar (TF, FT, etc) to eliminate the Teraflex trackbar bracket and still maintain all clearances? I also want to be able to remove the shock relo bracket. I am not sure if the trackbar will clear the RR spring without the TB bracket.
Old Jan 29, 2008 | 10:43 AM
Eracer76's Avatar
Im not sure about the Tera bar, but the FT bar works fine with no bracket and 3" of lift.
When I was running my RE 3.5 lift, I had the FT adjustable rear bar and no bracket.
Now that Ive got the 4.5" lift, Im using the FT bar with the RE drop bracket and its still fine.
