Stock Bumper Stubby Mod
Old Apr 15, 2013 | 06:28 PM
Irish Bullfrog's Avatar
Default Stock Bumper Stubby Mod
I know that this has beat to death but I had to share...
My stinger in on its way but I could no longer look at the stock bumper as it sat covering the front of my tires.. Knowing I only had two weeks until the new metal came in, I could live with it if my theory was wrong.. But I wasn't..
I have seen everyone just cut the ends off and either buy caps, leave the cut exposed, or just fabricate a flat cap to cover the ends.. I just knew that I could make two cuts and have a clean cap made from the stock bumper,,,, and I was right...
Bullfrog
ID:	447372   Click image for larger version
Old Apr 15, 2013 | 06:42 PM
camo_deerslayer's Avatar
Good job!!
Old Apr 15, 2013 | 06:44 PM
Originally Posted by camo_deerslayer
Good job!!
Thanks! I like it, but not enough to not put on my stinger and winch :-)
Bullfrog
Old Apr 25, 2013 | 04:59 PM
r2p2c2's Avatar
Default the price is right
Could you post more pics of the steps you took from start to finish?
Could you give an in depth list of instructions on how to make a stock stubby.... I plan to do it tuesday
Old Apr 25, 2013 | 05:45 PM
Didn't really document it all that much honestly.. I eyeballed a distance from the end and used a 4" grinder with a cut off wheel to make the cap part.. I then took a reciprocating saw and eyeballed about 2" outside the frame bump outs.. I then shoved the ends into the cut part until they looked even, marked them, applied epoxy and shoved them back in.. It was super easy.. The caps did require a little grinder "fitting" on the backside, but it was obvious once your there. PM me and I will text you some pics and be available to answer questions if you have any.. Good luck bud..
Bullfrog
