Clicking from Rear when Accelerating from Stop
Old Sep 4, 2013 | 05:27 PM
mpullum's Avatar
Default Clicking from Rear when Accelerating from Stop
I was wondering if anyone knows what may cause a click sound when accelerating forum a stop? It appear to come form the rear (possibly control arms?). I added a Teraflex 2.5" budget boost and have re-tightened all of the bolts at the upper and lower control arms, the track bar and sway bar links. Before putting back on the lift and pulling everything apart, I thou I would start here. Any thoughts or ideas of what to looks for would help. The noise started about 1,000 mi after the initial install. I have also noticed some "creaking" sounds when accelerating/decelerating. When I have attempted to flex the suspension or to bounce on the side rails or bumper to create suspension movement, no sounds. Confused?
Old Sep 4, 2013 | 05:49 PM
Flexer07's Avatar
Mine previous sport did this. It is the control arms or mine was.
Old Sep 4, 2013 | 06:34 PM
mpullum's Avatar
We're you able to get it to stop? Possibly they are not torqued enough?
Old Mar 15, 2019 | 08:14 PM
AlexWladimir's Avatar
Default Help
Hi Friend
I'm having the same problem, I have 2 1/2'' boost lift 33.75" tires and 4.88 gear, the clicking noise starter right after 100 miles. Did you find out your problem ? It looks like we have the same problem.
Thank you
