Bolt size for passenger handle bar
Old Sep 13, 2013 | 12:20 PM
MAG00's Avatar
Default Bolt size for passenger handle bar
On the passenger side, the handle above the glove box as a bolt on either end. I believe it takes an allen wrench. Does anybody know the bolt size (threads, length, etc.) for this particular bolt?
Reason for asking is that I was looking at the RAM Mounts webpage and saw where you can order the ball with a threaded stud. I thought this may be a good way to mount a device in the jeep. Just replace the bolt with a RAM 1" ball and then you can use any of their arms/mounts for your device.
Thanks.
Old Sep 13, 2013 | 05:11 PM
lowendrider's Avatar
Someone correct me if I'm wrong but I think those are just fake bolts. Its just a trim piece that can be pulled off.
Old Sep 13, 2013 | 06:33 PM
Just_Q's Avatar
The 7/32 hex bolts come out but the do not hold the handle in. When I took mine off to paint i used the bolts as a lever to pry the handle off.
Old Sep 13, 2013 | 06:40 PM
JIMBOX's Avatar
Ifgyou wanna mount a laptop--getta passenger front seat RAM laptop/tablet adj mount-
It mounts to the front two pass. seat bolts--secure !
JIMBO
Old Sep 14, 2013 | 04:50 AM
Vin's Avatar
Vin
The hex bolts for the trim piece are fake, but underneath there are bolts that hold the handle on. I forget the size, but if you get instructions for the CoolTech Cobra 75 WX mount. I'm rushed for time now, but I'll post what I find later if no one comes up with the answer.
