are people still having any issues with the teraflex monster trackbar?
I had read a few posts that the bolts were not grade 8 and stripped and some said it had weak spot at the adjuster , but im somewhat impressed with the beefyness of it and teraflex video of it . it looks solid and not much chance of bending or weakness all opinions will be helpful thank you
I believe a few guys on here have actually busted the older version of the TF Monster Track Bar. They were busting where the track bar flattened out prior to the bend for the differential. Apparently Teraflex noticed this has happened and re-designed the bar. I purchased the newer design and have been pleased. As far as your bolts are concerned, you should upgrade all the bolts from your control arms to Track Bar to Grade 8. There are several threads on here that talk about the upgrades and new bolt sizes which are much better than stock. The new bolts with shoulders will fit much tighter and take away the play between the joints and mounts.
yeh im ordering the grade 8 kit but
btw are you guys using regular socket sets and torque wrench or are you using air type impacts is that torque hard to achieve by hand in those tight locations at track bar ? 125lb
kinda makes me wonder if the leverage can be done on ground with hand tools, the bolts seam very tight on there now !!!!!
Here is a photo of the 1st generation TeraFlex Track Bar break. I believe the re-designed 2nd Gen Track Bars adjustment is further towards the passenger side axle mount.
Sent from my obama monitoring device
good to hear cuz i just orderd one !
thanks for the opinions ! i know it might be overkill but im not in the mood to deal with shimmys again least if i feel one later ill know its not the MONSTER I GOT it to stop with a alignment , stabilizer shock, tires changed over to nittos, then rotated them again ! two days no shimmy i think i got it nailed now grade 8 kit and monster i think im good to go ! hell maybe some time ill even try a re ballance on rear tire
The hardware on the clamp was shit on the one I got last year. The bolts stripped while torquing to spec (with a calibrated torque wrench). Replaced with grade 8 hardware and it's all good. Can't complain.
do you remember the size grade 8 bolts you bought ?
