LoD slider install. Drill and tap.
Old Feb 9, 2014 | 03:47 PM
kfxbryan's Avatar
Default LoD slider install. Drill and tap.
Just purchased the LoD sliders and need to know the correct drill and tap bits needed. I have read that the tap needs to be 7/16in-20 but the drill bit sizes from 13/32 or 29/64 or 25/64. From those that have done it, what is correct?
Old Feb 9, 2014 | 04:00 PM
Invest2m4's Avatar
25/64 and 7/16 - 20 tap.
Do not use the bit in the Kawasaki set! See picture. The bit is wrong and too large.
Lastly, I hate regular drill bits. I'd use something like a step bit or annular. Regular bits won't drill a round hole. Trust me...
Old Feb 9, 2014 | 04:06 PM
Invest2m4's Avatar
Also, if you have a manual trans, you'll need to buy two bolts. And they're not easy to find...
Old Feb 9, 2014 | 04:42 PM
Gman*2007's Avatar
Just installed mine last week. 25/64 drill bit and 7/16 -20 is correct. First drill 1/4 pilot hole and the rest goes pretty easy. There are 7 taps to be made on each side.
Old Feb 9, 2014 | 05:05 PM
mattgt5's Avatar
I've installed. 4 sets of these. It's not that bad. I tack welded the tap into a socket so I could use it in a ratchet instead of an adjustable wrench.
sent from my work leash
Old Feb 9, 2014 | 05:11 PM
Invest2m4's Avatar
Originally Posted by mattgt5
I've installed. 4 sets of these. It's not that bad. I tack welded the tap into a socket so I could use it in a ratchet instead of an adjustable wrench. sent from my work leash
Great idea! I lost an adjustable wrench that day. Threw it in the woods behind my house. I might have been a little frustrated...
Old Feb 9, 2014 | 06:46 PM
mattgt5's Avatar
It worked great and I have two of them should I ever install some more. Socket was like a buck or two, cheap fix to save a lot of grief.
Old Feb 9, 2014 | 08:36 PM
mistasparkl's Avatar
You can use a 12 point socket on a tap to turn it. (12 pts are divisible by 4)
Old Feb 10, 2014 | 02:36 AM
Invest2m4's Avatar
Tried that. The socket size was really small and the torque required to tap the frame was too high. Ruined the socket almost immediately.
Old Feb 10, 2014 | 09:13 AM
SSmileys12JKU's Avatar
Just installed mine yesterday, bought the tap and drill bit off amazon. Used a 12 point socket with my 1/4" ratchet for the tap, PB blaster for cutting oil and had no issues. Well almost none, somehow had one of the holes marked wrong and am missing a bolt for the center mount spot on the passenger side. Although just a bit short the supplied bolts seem to thread into the blind nuts that have no existing bolts for us 6m guys. I said blind nuts huh huh huh. Will visit fasten all for the extra bolts.
