JK Fuel Pump GPH
Anyone know what the GPH of the stock fuel pump is? I will be needing an external fuel pump. Ive been looking at jk specific ones and they vary from 43 gph to 125 gph. Even on Autozone im not finding a fuel pump for the jk. I just need to know the ballpark gph so i can make sure the external pump for my fuel cell will provide enough. Fuel pumps are not my expertise at all, but I am learning a bit on these.
I would think most any electric fuel pump will be enough flow for the JK.
What's the most you will burn in an hour? 10 mpg is 6 gph at 60 mph.
Pressure is more important. The OEM pump is regulated to 58 psi +/- 2 psi.
What are your plans with the fuel cell?
Perfect, i figured youd be the one to help me out. I will look into the pressure then. Whats the consequences of running a slightly higher/lower psi? If i cant find exact is there a better side to error on? I appreciate your help.
I have no idea what pressure would be too high or too low.
LS1 Complete Fuel Delivery Kit - Speedway Motors, America's Oldest Speed Shop
this looks perfect.
MSD 2225 In-Line Hi-Pressure Fuel Pump - Speedway Motors, America's Oldest Speed Shop
but when i look up just the pump this is the specs.
From what i can see the kit has a regulator that keeps the psi stable where i would need it correct? But wouldnt the psi very depending on rpms/ the need for gas?
this looks perfect.
