Another stock speing question
Old Jun 4, 2014 | 05:07 PM
cormac827's Avatar
Could not find my springs part numbers. Looking at buying a 4dr 10a rubicons springs and shocks for some cheap lift. Anyone have any idea on if it's worth it? Are the red 10a rubi shocks worth work to upgrade as well(cost is cheap)? I couldn't find my 63 part number for my shocks by its hard to search I apologize in advance if it's right out there. I bought my jeep used and it has these on it. Front: Click image for larger version
ID:	557658 Rear: Click image for larger version
ID:	557659 Click image for larger version
ID:	557661 This guy is selling these: Click image for larger version
ID:	557662 Click image for larger version
ID:	557663 Click image for larger version
Edit: main question is how much estimated height on stock weight?
Old Jun 4, 2014 | 06:00 PM
jadmt's Avatar
JK-Forum Ambassador
shocks are an upgrade over sport shocks and I can tell you that the 10A front coils lift about 1" vs -18 front coils as I have a 2014 Rubicon 4 door and it came with -18 coils up front and the 10A -06's lifted it about an inch.
Old Jun 4, 2014 | 06:12 PM
cormac827's Avatar
Sweet! Yeah I'm not sure what that front coil is "52126313ac"
Old Jun 4, 2014 | 06:38 PM
jadmt's Avatar
JK-Forum Ambassador
13's and 54's in those photos so if those are your coils you will get well over an inch probably 2" or so.
Old Jun 4, 2014 | 06:42 PM
catahoula's Avatar
You could always add some spacers if you want a tad more. I installed 18/59's with TF leveling kit. Really happy with the results.
cormac827's Avatar
Awesome
Old Jun 4, 2014 | 06:43 PM
cormac827's Avatar
Cool! Wondering- don't want my stock geometry too messed up! Trying to do 35"a with this and xrc armor fenders.
Old Jun 4, 2014 | 06:44 PM
cormac827's Avatar
If I put bottle jack between axle and body, will it separate enough to drop out old springs?
Old Jun 5, 2014 | 05:10 AM
Shearlow's Avatar
Unhook your shocks and sway bar links and lift at the frame on one side at a time. The spring will almost fall out by itself. Put the new spring in on that side and move to the other side. Do not put a bottle jack between the body and axle unless you are looking for some custom body work as a result!
Old Jun 5, 2014 | 05:33 AM
cormac827's Avatar
Lmao- thanks! I'll do it your way :-)
