Help removing Plasti-dip that is too thin
Old Jun 12, 2014 | 06:11 AM
wittys-jk's Avatar
Default Help removing Plasti-dip that is too thin
I sprayed my grill with dip and I sprayed it too thin and now I have some bare spots that have since began to peel from normal use. I have done some research and know that there is a product that dissolves it for $20 a bottle so I wanted to check here to see if anyone has any experience. Some say goof-off pro strength and others say tire magic silicon tire spray with a pressure washer. I am leaning towards just spraying right over the old dip and building on what is there.
What says the JK Forum?
Old Jun 12, 2014 | 07:07 AM
HELLBENDER-JK's Avatar
Spray it with more dip
Old Jun 12, 2014 | 07:18 AM
crazyhorse02's Avatar
Rub it off or just respray it.
rooster1976's Avatar
Spray with more or wd40 will take it off
Old Jun 12, 2014 | 07:28 AM
wittys-jk's Avatar
Have to give WD40 a run I didn't think of using it.
Old Jun 12, 2014 | 07:34 AM
JustJeepinWithYa's Avatar
Took plasti dip off all four of my wheels with wd40. Spray on, let soak 5 min, rub off with shop towel. Super easy!
Old Jun 12, 2014 | 07:35 AM
Chefbrujo's Avatar
If ur going to re-dip it there is nothing to think about. Just respray it.
Old Jun 12, 2014 | 07:42 AM
5110's Avatar
WD40 or just re spray
Old Jun 12, 2014 | 08:27 AM
wittys-jk's Avatar
Thank you guys I am going to hit it with fresh dip for now and keep the WD40 as a back up plan if I decide to remove.
Old Jun 12, 2014 | 08:58 AM
eclipse3319's Avatar
http://youtu.be/4T0jEvxxTzE Here is a how to, any thinner will work
