Using 4 jackstands.
Old Aug 25, 2014 | 07:14 PM
BlackdogJK's Avatar
Default Using 4 jackstands.
This may sound dumb but I'm about to put my jeep up on 4 jack stands so I can do some repairs. Is it as sketchy and I feel it will be? I've never done all four before but it seems like there's really no safe way to do it.(especially with an uneven driveway.) how do you guys go about doing this properly?
Old Aug 25, 2014 | 07:28 PM
jaker t5's Avatar
No problem putting the jeep on 4 stands just make sure you use the right stands 6 ton are great , I would not do it with 3 tons
Putting the jeep on stands is not that much different then tires so keep your stands near the end of the axle the best way you can for stability
My jeep has been on stands many times but here is an idea of what I was saying
Old Aug 25, 2014 | 07:46 PM
Jeepstin12's Avatar
Originally Posted by jaker t5
No problem putting the jeep on 4 stands just make sure you use the right stands 6 ton are great , I would not do it with 3 tons Putting the jeep on stands is not that much different then tires so keep your stands near the end of the axle the best way you can for stability My jeep has been on stands many times but here is an idea of what I was saying
. Why not 3 ton? Each wheel is rated 1/2 to 2/3 of that.....
Old Aug 25, 2014 | 07:53 PM
Rob 12B1P's Avatar
Heavier rated stands are taller. Makes it easier to work on the vehicle. I use 6 ton.
Old Aug 25, 2014 | 07:55 PM
jaker t5's Avatar
The main reason is height followed by weight , but I rather be over then even or close with weight
Old Aug 25, 2014 | 07:58 PM
Jeepstin12's Avatar
undertsand. I'm just thinking 4 stands total, at 3 ton each is plenty. But, I'll take your word on the height. That, I get. The weight? I guess I can agree on being over. I have a set of 3 ton I've used on my Land a rover, which outweighs my jeep by nearly 1500 pounds and never had issues. Thanks for the feedback! Something to consider. I would just like a lift on my garage. Maybe the next big tool.
Old Aug 26, 2014 | 12:57 AM
Mark Doiron's Avatar
If feasible for the work you're doing, place your tires where they would catch the Jeep should something go amiss. It will make you feel a little more comfortable. As for stand rating: I use 3 tons and would not want the Jeep any higher. I get tired having to work with my arms stretched out even further. But that would depend on the job. At the end of the day, having a friend with a lift is the best thing, LOL ...
Name:	Jeep Work, Jan 13, N7-3458, On Lift.jpg
Old Aug 26, 2014 | 02:35 AM
BlackdogJK's Avatar
I forgot what forum I was on. This is actually for my tj. 3 ton jacks should not be an issue.
Old Aug 26, 2014 | 02:50 AM
MikeRM's Avatar
Another point for using 6-Ton stands is the base has a larger footprint on the floor=better stability.
Old Aug 26, 2014 | 04:33 AM
Jiblet's Avatar
Asphalt driveway? Make sure the feet of the stands won't sink into the asphalt. Some stands are just sitting on the edges of their angle-iron legs. That's ok on concrete but I've seen them sink into asphalt.
And Mark's advice about positioning tires underneath is spot on. Better safe than sorry.
