How to install a kill switch in a 2012 or newer?
Old Feb 22, 2015 | 06:49 PM
Jeep305's Avatar
Default How to install a kill switch in a 2012 or newer?
Does anyone have a wiring schematic on how to wire a kill switch to the ignition or clutch switch? Jeeps are being stolen left and right from my area.
Crush '12 JK 2 door, 3.5 metal cloak, FOX, 5.13, and roll'in 37's.... killin it in WV mountains!
Old Feb 22, 2015 | 07:42 PM
NewOldSchool's Avatar
Bump to the top. I am looking to do this too. Thanks.
Old Feb 22, 2015 | 07:54 PM
LidLess07X's Avatar
I wired a switch into the ground wire for my fuel pump. I don't have a diagram but basically you just interupt the the ground wire.
Old Feb 22, 2015 | 09:13 PM
mblue's Avatar
Theft deterrent.
On a more serious note I am looking to installing a simple start interrupt in my 2012 JK, I am dumb enough to shoot someone for trying to steal my Jeep so I guess I should make it harder to steal.
Old Feb 22, 2015 | 10:10 PM
k0260's Avatar
one thing that helps if you have the ability to lock your hood, a battery disconnect. I use the 'turn knob' style that hooks up directly to the battery Click image for larger version
ID:	598292edit: good addition for those of us without an alarm
Old Feb 23, 2015 | 02:05 AM
14Sport's Avatar
With chipped keys, everything I've read is that it isn't needed. I've put immobilizers in all my vehicles and was prepared to do the same with my Jeep until I read about the chipped key being enough on the forums.
I did, however, add a flashing LED to the dash to discourage kids who don't know about the chipped key.
https://youtu.be/RYkgHyJ7TC8
Old Feb 23, 2015 | 02:19 AM
DJ1's Avatar
DJ1
Former Member
My thoughts exactly. If they're gonna steal it, they're gonna use a flat-bed to haul it. I'd rather keep the battery connected so at least the vehicle alarm will trigger and the Mopar hood lock I have will buy me enough time so I can hear it go off....
Old Feb 23, 2015 | 06:45 AM
ronjenx's Avatar
The immobilizer is its own kill switch. It cuts off the ignition, and maybe even the fuel.
Have thieves figured out a way to fool the immobilizer?
Old Feb 23, 2015 | 06:53 AM
14Sport's Avatar
Not the one I installed in my T/A. I used a reed switch and magnet in the key fob.
I was going to do the same setup in my JK but with chipped keys, not necessary. At least from what I've read.
Old Feb 23, 2015 | 11:17 AM
Jeep305's Avatar
Unfortunately, in the last 2 months I've had two friends loose their jeeps because a duplicate was made from a dealer. The chip is great if their not using a copy. All they do is take a pic of your Vin and bam, one phone call and a key is made for your ride. I rather add a kill switch and not a battery disruption under the hood. I rather be able to flip a switch instead of un latching my hood in snow to start my car.
