5" wheel backspacing on 2011 JK??
Old Apr 3, 2015 | 08:27 PM
3 tons's Avatar
Default 5" wheel backspacing on 2011 JK??
It was suggested to me by Quadratec that for some reason (??) 5" backspacing was not doable on my 2011JK 2dr sport, but ok on previous year JK's...This seems somewhat strange to me...The wheels I'm looking at are 16"x8" with 265x75 tires planned. Also, I'm confused on whats the difference between backspacing and offset??
Black Rock Wheels 952685050 - Black Rock Series 952 Street Lock Steel Wheel in Matte Black for 99-10 Jeep® Vehicles with 5x5 Bolt Pattern - Quadratec
Any advice or caveats for the 2011 JK wheel status would be greatly appreciated!
Thx,
3 tons
Old Apr 3, 2015 | 09:24 PM
nthinuf's Avatar
Offset and backspace are different ways of determining how far into, or out of, the wheel well the rims sit. Offset is more accurate, but it uses rim width in the formula so is a bit more difficult to understand and use. If you see offset in the desciption, just use an online converter to get the backspace equivalent, then compare that to the stock backspacing.
As far as those rims go, my guess is that they are confusing the 16" rims with 15" rims that are known to need less backspace to clear the calipers, or they are thinking about future upgrades to aftermarket steering components or big brake kits that will require 17" or larger rims.
Old Apr 4, 2015 | 10:24 AM
Strider's Avatar
I have a 15, and run 5 in backspacing with 305/70/16 tires. I have no problems with them rubbing whatsoever. I don't offroad though so don't no how they would be when the suspension is flexed. Below is an easy converter for backspacing vs offset, hope it helps.
http://www.ccwheel.com/technical-converter.php
Old Apr 4, 2015 | 11:26 AM
tribulation138's Avatar
http:/www.ccwheel.com/technical-converter.php
How 305/70/16 even fit on 15 inch wheels.. confused?
Old Apr 4, 2015 | 12:02 PM
Strider's Avatar
I have a 2015, not 15" rims. OP stated they had an 11. I wanted to make the distiction between years. I can't see there would be a differance between a 15 and an 11.
Old Apr 4, 2015 | 03:40 PM
3 tons's Avatar
CCW - Complete Custom Wheel // Technical - Offset Backspacing Converter
Thanks very much, but are they 8" width and do you know what the offset is?
3 tons
Old Apr 4, 2015 | 06:44 PM
Strider's Avatar
I have BlackClick image for larger version
ID:	604859rock Dune 941 16X8 wheels with a 5in BS and I believe 12 offset. You can look them up on the Blackrock website.
Old Apr 4, 2015 | 08:31 PM
3 tons's Avatar
I have BlackAttachment 604859rock Dune 941 16X8 wheels with a 5in BS and I believe 12 offset. You can look them up on the Blackrock website.
Got it, thanks for the details!
3 tons
