Warrior Products axle back exhaust with Magnaflow?
Old Apr 17, 2015 | 11:33 AM
deathwagon's Avatar
Default Warrior Products axle back exhaust with Magnaflow?
I really want to install a Flowmaster 50 series on my 2013 because I like the mellow, non-obnoxious tone. Unfortunately, all local shops in my area seem to use solid gold welding rods, because they all want $340 or more for one installed. When I weld, it looks like someone projectile vomited molten metal, so I'm looking at inexpensive bolt-on units. Has anyone installed the Warrior Products high clearance kit with the Magnaflow can on a 3.6L?
Warrior Products 2240 - Warrior Products High Clearance Exhaust Kit for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
Comments on quality, noise level and drone?
Thanks
*Edit- I guess it's not actually an axle-back, but a resonator- back
Old Apr 23, 2015 | 06:36 AM
deathwagon's Avatar
I'll respond to my own post since there was no other feedback. I'm a cheap ba$tard but I'm also kinda picky about how an exhaust sounds, so I decided to try out just the muffler before committing to the whole kit. The muff in the Warrior kit is a Magnaflow 11216 and it goes for $80-ish dollars. I also spent $7 on two saddle clamps. I lopped off the resonator and installed this can in it's place. It's a little wider than the stock resonator and had to be rotated slightly to avoid interference with the evap skid.
I wont be keeping it, as it sounds very sport-importy. You know, the sound you hear coming form the Honda Civics with oversized shart cans installed. Maybe a little smother than that, but ricey. It also has significant drone. I can't say if the whole kit from Warrior would sound better, since I didn't spring for that. If there's any interest, I could post a video on Youtube of how it sounds.
Old Apr 23, 2015 | 06:49 AM
DunnyBunny's Avatar
JK-Forum Ambassador
Check out Dynomax. Alot of good feedback and alot of people running them. They have a rep on the forum and just do a Google search of JK Dynomax. There are many threads on them and youtube videos
Old Apr 23, 2015 | 09:56 AM
deathwagon's Avatar
Thanks for the suggestion. Unfortunately, the only Dynomax offering in my price range (did I mention I'm a cheap S.O.B?) is the Super Turbo Axle Back system, and even the Dynomax guy admits that it's known for it's drone. So it looks like I'll buy a Flowmaster 50 can and do my own splattertastic welding job.
Old Apr 23, 2015 | 11:13 AM
Dynomax's Avatar
Sponsoring Manufacturer
Stack your stock resonator and the muffler of your choice. Why not use clamps?
Old Apr 23, 2015 | 12:12 PM
deathwagon's Avatar
I'm using clamps until I find the right combo and then I'll weld up whatever I choose. Clamps tend to result in leaks.
